Hey all, I’ve tried searching forums and can’t find exactly what’s happening to me so I thought I’d make a new post, forgive me if this is the wrong area, but I do need an opinion.
I’ll start by setting up the picture, so I bought an NA r32 about 5 years ago, it IS factory RB20DET however the previous owner had an expensive set up previously I believe so he removed the turbo parts including manifold turbo etc etc and put NA parts on the turbo motor, so just straight headers and some chunky welded exhaust with an NA computer and HORRIBLE wiring harness (chopped and spliced everywhere).
So about 2 weeks ago I had enough of not being able to keep up with literally anything as it would run horribly, and converted it to turbo, I just finished it today, I used some parts from the various RB25det’s and parts I have laying around since I’ve had a couple skylines, so I’ve changed the following
-RB25DET turbo - New lines - RB20det ECU (second hand) - new wiring harness - front mount intercooler - I fabricated my own intercooler piping (no leaks) - rb25 AFM ( I have the original 20 AFM as well) - new radiator and new exhaust system and dump pipe.
After putting it all together today, it won’t idle, now it could be because I’m super tired and been welding and just can’t think properly and I may be missing something but I need an opinion, if I unplug the AFM it’ll run, but idle at around 2000RPM and just sit there and if I go to rev it, it’ll just bog down, if I unplug the TPS (with AFM plugged in) it’ll start run on 1000 for 2 seconds and then die slowly and turn off.
If you guys need any more info just ask, I have some ideas but I’d like to see what you RB experts have to think about it.
Any help will be appreciated.
https://www.sau.com.au/forums/topic/482077-r32-rb20det-won%E2%80%99t-idle/
Oh, I did misread.
Either the AFM wiring is not right, or the idle control wiring (or the IACV) is not right.
Or, the million other random things it could be a car that has been hacked apart and then hacked back together. Seriously, just one wrong wire somewhere could cause all this.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
