Hey guys,
I hate myself for even asking this because I normally don’t buy these types of things
But has any purchased one of these intake manifolds off AliExpress?
I just spent $1450 on a 6boost exhaust manifold and would like to cheap out on the intake so I can spend more money and get a better intercooler
any feedback appreciated!
  • Haha 1
https://www.sau.com.au/forums/topic/482172-intake-manifold-aliexpress/
No idea how things have changed but about 7 years ago a friend bought the "Freddy" manifold for his RB25. He ended up having to do a lot of clean up and porting with a dremal, buying fittings for the water lines and the head ports didn't quite match up either.
Ultimately he got it on the car and it likely worked as well as a Greddy however he said he it was a POS and would never do that again.
I'd rather cut and shut the factory manifold over buying one of these abortions.
Yes they work if you machine the flange on it.
But they weigh at least half as much as an rb, no honestly they're heavy as and the casting on the inside of the runners is sketchy. I wouldn't trust some of the casting slag to come off and get sucked into the engine, just not worth the risk in my opinion.
Factory intake is good, multiple people have used them over 450rwkw.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
