So every since the conversion if have a miss-fire. It seems to happen in the rev range of 1100-2500.
The car was sitting for a few months during the conversion.
1. Changed the plugs
2. Coil packs are brand new
3. Unplugged coils one by one, they all display similar behaviour
4. Sprayed all over vacuum hoses etc with brake cleaner, can't hear anything change
5. Vacuum tested when running, looks normal.
6. Unplugged the O2 sensor, no change. ecutalk is seeing voltage.
7. Swapped CAS with another good one
8. Resistance check the coil loom
9. The battery was disconnected for weeks during the conversion, so the ECU has been reset.
I have a consult (ecutalk), but I don't really know what to look for, other than error codes, which there are none.
I am running out of ideas.
PS It is a N/A
Usually with all the skylines I’ve owned issues at 2500rpm always seemed to be related to the air flow meter. Usually when the AFM is dead it limits your revs to 2500. Your one might be dirty as f**k inside it, or you may be even using the wrong one. So clean it with contact cleaner or afm cleaner. Just make sure one side of the afm has the mesh on it though, because removing that also causes problems. Also check the afm wiring, it might be loose or come off.
I would also clean the inside of the boost solenoid.
Thanks. I will clean it and check the wiring. But I have not changed it during the conversion. I think it is OG. I wish I had a boost solenoid. NA.
It does rev right out. It is just missing a bit and feels like a vibration in the lower revs.
Cleaned the AFM and throttle body.
Still no change.
I am starting to wonder if the flywheel or pressure plate is out of balance and what I am feeling is a vibration.  It does increase with revs and there is a small vibration on the clutch pedal in the high revs.
  • 2 years later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
