Hallo guys. I have a Nissan Skyline V35 250GT. I hav seen the car has a fuel tank split into two, possibly the main tank and the reserve tank. In the main tank is the pump. My problem is fuel is getting finished in the main tank whilst there will be fuel in the reserve tank.Are they not supposed to decrease in level at the same time? How is fuel added to the main tank from the reserve? I see there is a fuel pipe from the bottom of the reserve tank to the pump filter.How does it work and what could be the problem.
20210906_164714.thumb.jpg.8cc5410453c2c9d991a1630c9268b556.jpg 20210905_174539.thumb.jpg.252b0fb8be4badb4d5c80057a114c4d9.jpg
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/
it is one big tank, not a main and reserve, but due to the shape of the vehicle it is high in the centre, there is what is called a 'jet pump', which is responsible for moving fuel from the side without the pump to the side with the pump.
see this page for a description.
https://www.sard.co.jp/after_eng/products/engine/jp_killer/jp_killer.html
This isn't quite the same as the V35, I believe the 250GT is the same as the 350GT and has the pressure regulator built into the fuel pump assy, not external like the image in the link.
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7955651
Yuh, they are referred to as a "saddle tank" because they go up and over the horse in the middle. As @sonicii above says, there is usually a venturi type pump that runs from the return flow or similar to draw fuel from the dead side to the live side (live side being where the main pump draws from).
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7955671
Sorry for the late response guys but would like to thank you for your responses.V35_Paul --- Yes I am running out of fuel yet there will be fuel on the other side of the tank. The 250GT has a single line from the pump to the engine and another line from the other side tank (dead side)onto the pressure regulator as shown in pics below. Any idea as to why we have 2 level sensors one on the dead side and the other on the live side attached to the pump.
20210906_164701.thumb.jpg.6ccff885b317e894cebf7335338efd9c.jpg  20210905_174936.thumb.jpg.d0714c2b33c34d446c64c95ace333217.jpg
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7955947
That orange component you can see in your pictures is the jet pump, it is responsible for transferring fuel from the 'dead' side of the tank if the fuel level in that side is higher.  If this isn't happening then I would be looking for issues with the hose or the jet pump.
Keep in mind the 'jet pump' isn't an active pump, it is venturi device that depends on the fuel leaving the pressure regulator and returning to the tank to draw fuel from the other side, so there could possibly be issues with the pressure regulator or the venturi device.
  • Like 1
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7955978
Also just make sure the Fuel sensor is clean.
VERY common that they give a false reading to your fuel gage. E.g if you Fill "to the top" car up and it shows just under the "Full" line then its wrong.
Just use a cotton tip to rub the metal contact points on the sensor attached to the pump
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7955996
^^ yep, that is true too.  Except mine of course, it likes to randomly read high, cleaned sensors and connectors, checked for damage/debris on the level sensor, still happens through.  Almost as if one sensor occasionally decides to read 'full' when it isn't.
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7955999
  • 4 weeks later...
  • 1 month later...
Guys does anyone have any idea as to why the Nissan skyline 250 GT has 2 fuel sender units (fuel sensors).Whats  the purpose of the fuel sensor in dead side of the saddle tank.What's the part played by this sensor since there is another sensor in the live side of the tank where the pump is situated.
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7958633
Guys let me share with you my observations on the operation of the 2 fuel sender units on the Nissan skyline 250GT.I pulled out the 2 sender units out of the tank and switched the ignition key to ON position.I was moving the floats on both sensors simulating different tank levels while observing the behaviour of the fuel gauge.For my experiment the dead side tank was 2 and the live tank was 1.For the sensor positions Low meant empty, Mid was half tank and High was full tank.
I made the following observations
  1. If both tanks 1 & 2 sender units are set on Low, the fuel gauge will indicate empty
  2. If sensor in tank 2 is set to Low and  as you move your sensor in tank 1 from Low to High the fuel gauge moves from empty to maximum half tank.
  3. If sensor in tank 2 is in Mid position to High and as you move your sensor in tank 1 from Low to High the fuel gauge moves from empty to full tank.
So in conclusion there is some form of synchronization between the 2 sensors.The fuel gauge reading is a result of the synchronized positions of the dead side and live side fuel sender units.
  • Like 1
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7958785
the sender are in series, there is only 1 fuel gauge circuit that passes through both senders, for the gauge to read full both senders need to have minimal resistance, which is what they have at/near the full position.
If you unplug either sender, you break the circuit and the gauge will read empty no matter how full the tank is.
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7958803
  • 1 year later...
Possibly, there are 2 level senders as there is 2 halves to the tank (saddle tank), even though they are connected internally, one side can be higher than the other, so to give a genuine reading, there is a sender on both sides.
As for why it is reading high, I wish I could work out that on mine (or my son's car now), it intermittently reads high, I have removed, cleaned and tested both level senders and they seem to be fine, checked the wiring as much as I can, but still can't work out why it sometimes reads high.
Usually when you have a dirty sender it reads low.
https://www.sau.com.au/forums/topic/482805-v35-fuel-system/#findComment-7984510
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
