I am in process of refitting the aircon in my 32 With rb25 in it, swap was done by previous owner.
So heating and cooling lines have completely been deleted including compressor, I am aware that I need a rb25 compressor but what about the lines for both heating and cooling and wiring ?
Really appreciate any help, before I go to a ac place.
thanks
On 9/9/2021 at 5:21 PM, r32-25t said:
You need an r32 compressor and lines and everything else
Well..... So long as the R32 compressor doesn't have a problem with belt alignment, then yeah, sure. I don't know if there is a belt problem with a 32 compressor on a vanilla 25. I do know that the R32 compressor won't work against the Neo's belts. Well, not without having to do something about pulley alignment and/or different pulleys, which could all be possible, with some work.
I put a Neo into my R32, used the Neo/34 compressor, got an airconditioning workshop to cut and shut the refrigerant lines (R34 ends at the compressor onto the original R32 lines, welded at the alloy pipes).
I also had to f**k around endlessly to sort out the different pressure switch and the different way that the R34 ECU talks to the AC controller. Was without air for a couple of years until we got that sorted out. Not that it matters because I seldom use the air con anyway.
Oh, you also have to convert to R134a with the R34 compressor to, which means different receiver-dryer and ports and some other stuff.
Its a rb25det s2, so thinking of getting the compressor for which came on it originally, lining up things shouldn’t be a problem in that case.
Which I am more curious about are the lines.
will I need lines out of 32 or 33, I know it be different fitting here and there, but someone who has already gone through all this would be bonus.
@GTSBoy
please correct if wrong, all the things mentioned below are I figured will be needed as they are currently non existent.
r32 line from drier to condenser
1 ) Line from condenser to compressor? ( I believe fitting on condenser should be r32 ones and compressor side might be different)
2) Line from compressor to dash cooling unit ( same as above I think mix and match?)
3) Line from condenser to dash cooling unit
I am not 100% sure how exactly lines are on 32s, I am referring to the attached diagram.
Just want to suss out as much possible on my end, Eventually will be taking her to a ac shop to get it all going, but getting them to do all those fitting will land me to second job.
Appreciate your input.
On 10/09/2021 at 6:08 AM, r32-25t said:
I just did it the easy way and fitted the rb20 balancer on the rb25 but with the r33 rb25 the ac belts line up it’s just the power steering that doesn’t
Was thinking of doing that, how did ya line the power steering then ?
Used all the r32 accessories, alternator, power steering and alternator
  • Thanks 1
I can't help you with the details. As I said, I put a Neo25 into my car, and everything is different from vanilla25. And I did not use complete lines. I had the compressor ends of BOTH lines cut off the car's lines and I had the ends to suit the 34 compressor welded on.
  • Thanks 1
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
