rb25det r33 unstable idle + hesitation + black smoke / error code 54
Hi everyone,
I've done some searching on the forum, however couldn't find something which exactly matches my issue or has solved it.
The issue is relating to unstable idle on start up where revs fluctuate and black smoke can be seen from the exhaust with a noticeable fuel smell.
After about a minute, the revs will start to stabilize but if gas pedal is pressed it worsens the rev fluctuation. soon after plugs become sooty.
Note: I've attached a video of what happens
Troubleshooting I've done so far:
  • CTS replaced, tested wiring (good ground and other wire giving 5volts)
  • adjusted timing to 15 degrees
  • checked for vacuum leaks around the intercooler pipping and engine bay > measured vacuum at -17hg
  • changed plugs
  • MAF sensor tested (signal wire showing voltage change, car stalls when unplugged)
  • coils tested (engine hesitates when each one unplugged, resistance testing consistent throughout the 6)
  • tested with o2 sensor plugged and unplugged
Car was running fine a week ago. in some cases if i unplug the battery and clean the plugs it runs smoother.
The car is running a stock ecu and at times throwing error code 54 on the dash which is A/T Control.
It has a manual transmission but i realized the ECU is for automatic (MEC R531 A1 4225)
Could this be possibly causing the issue?
As you can see I'm currently running out of ideas looking for some possible causes/solutions.
Thanks
Ray
No. It'll be fine. But you should set the timing to suit the ECU, which probably wants 20°, being an auto. Not a big issue, you're just running 5° retarded.
Check your fuel pressure.
That's good to know, i did end up adjusting the timing to 20° to help with idling issues.
I currently don't have a fuel pressure gauge to check.
But i did check that the Fuel pump primes and the pressure build up in the lines can be heard just before the pump stops.
Also when i open the filler cap it makes a 'tisss' sound.
The issue is:
Black smoke from exhaust
hesitation/rev fluctuation
- spark = yes
- coils = good
- FPR = untested
- Injectors = untested
- fuel filter = good
I'm started to think the issue could be relating to the injectors or fuel regulator.
more testing tomorrow to try and identify the issue..
On 9/23/2021 at 8:32 PM, GTSBoy said:
Check that it is not too high, not that it is too low. You will need to use a gauge.
I ended up testing with a gauge. On prime fuel pressure jumps to 50psi then back to 0.
See video.
i tested with another fuel rail and the same thing happens. The pressure doesn’t hold in the lines and dropped after fuel pump stops.
After changing the rail car is not starting, when cranking I noticed the cat overheat warning light comes on. Might need to check if the Cat is blocked.
So there are the issues:
- car no longer starting
- not holding fuel pressure on prime
- cat overheat warning light (might be blocked)
Maybe a little too high.
then back to 0
How fast?
What do you mean, "changing the rail?"
Also used as CEL. Now you have a code to investigate.
(might be blocked)
Yeah, nah.
On 9/25/2021 at 11:14 AM, GTSBoy said:
How fast?
Straight away (as per video)
i replaced the rail with another one, complete with injectors and FPR. After installing, car won’t start.
Also used as CEL
By CEL do you mean relating to an ignition problem?
the ignition loom was converted from series 1 > series 2 and ignition coils changed to s2 ones with the (igniter at the top)
I can confirm the 1st 2nd and third plug is giving spark. (See pic)
More checks:
- cat = removed not blocked
-  coils = Resistance test relatively consistent on all 6
- spark good tested on cyl 1, 2, 3 (by grounding to the rocker cover)
- still investigating why cat overheat light started turning on when cranking..
I don't generally watch videos posted in these threads as they are almost always useless.
CEL = Check Engine Light.
Something you did wrt the rail swap is wrong, or the injectors or FPR are faulty. Put back the proper stuff. Don't report fuel pressure behaviour on different equipment to that which possibly caused the problem without first reporting the behaviour on the original equipment that was on the car when reporting the problem.
Also worth noting - The videos don't seem to work (at least when I clicked on them)
Troubleshooting methodology is better than most Mr GTSBoy 😛
Generally though - Why swap a rail? How could a rail fail other than it leaking? And if it leaks with 50PSI you will absolutely note it is time to replace the rail.
Fuel pressure doesn't stay indefinitely. It also doesn't drop away straight away. I doubt we have a tunable ECU in there to see what is going on, in which case you'd better make sure you're running stock injectors, stock rail, stock FPR and basically stock everything if you're going to use the stock ECU's error codes to diagnose stuff.
On 9/27/2021 at 9:13 AM, Kinkstaah said:
Why swap a rail?
I had access to spare rail which included the injectors and FPR. That way if the issue was relating to a leaking injector or FPR issue it would be sorted.
However the fuel pressure it still not holding.
iv changed the FPR as well and no luck.
note: old fuel rail setup has Since been reverted back
We know that there is definitely a fuel pressure leak.
fuel leak down test = failed (pressure drops instantly)
The question is where is the leak occurring..
possible causes
injectors = no leak from any while priming
FPR = tried to pitch the short hose on the FPR while pump was priming and the pressure shot up to 100psi but after pumped stopped went back down to 0
In saying that iv tried another FPR with the same result.
Either the 2 FPRs I have are faulty or something else is causing the Pressure drop.
Fuel tank lock ring
One other observation is that The lock ring where the fuel pump goes in the boot is split. fuel pressure might be escaping from there.
I’ll replace this first and see if that changes anything.
The pressure should drop. Maybe not instantly, but it should. It doesn't just hold the pressure indefinitely when the engine is off and the fuel is not pumping.
If it did, there would be no need to prime the fuel system... ever. If the pressure is dropping or being too high (or really, fluctuating) while the engine is running then there's an issue with the FPR.
If you have two sets of stock injectors, and two stock FPR's and two fuel rails, I wouldn't be chasing the fuel side of the engine bay at this point for your problem.
Personally I'd be re-checking that MAF (is it the same auto/manual/is it clean? did you actively clean it with MAF cleaner?)
Alternatively, anything else custom in that circuit?
You have spark, but do you know you have spark at the right time?. You've set timing to 15deg, but have you checked it with a timing light? Could it be out? Whats your CAS doing?
yes the MAF was cleaned, voltage was checked (12v, signal voltage and ground are good)
On 9/27/2021 at 3:42 PM, GTSBoy said:
Check valve. It'll be the check valve.
That's what i'm starting to think. The check valve is in the fuel pump (Walbro 255). I will be replacing the whole pump.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
