I'll explain.
I want to keep my options open regarding modifying my car, and to this end I have decided if I end up modding the R34, I'm going to pull the engine out complete and keep it together, and build another engine complete to put in and thrash/risk. Aim is to go modest, keep the new motor stockalike with around 400 whp, so I shouldnt need to do anything crazy with the rest of the drivetrain.
Preaching to the choir here, but parts for RB26's are getting harder to come by and more expensive. Trying to find a R34 RB26 is proving quite hard, and I would imagine even if i could find one it would be ridiculously expensive. I have found a RB26 that looks to be in decent condition that suits my plan, but has a 2WD sump attached. I have now found a RB26 sump off a R32 GTR, so I now have a 4WD sump to go onto the RB26. Only problem is final drive ratios.
What are people's opinions? I have found the part No. for the R34 GTR front diff final drive gearset, 38100-00V00, but they are discontinued and are probably going to be hard to come by, but it seems in my (unqualified) opinion to be the easiest way forward?
Anyone ever used this kit? https://www.nengun.com/tomei/final-gear-set
What about the Quaife front/rear diffs for the GTRs? (I don't know enough about the kits and what they replace.)
The car is a V-spec, which means if I go the other way and change the rear diff I will have to remove the A-LSD which seems to be another giant pain in the ass too.
How crazy would it be to remove the entire rear drive assembly and replace it with a R33/R34 GTR frankenstein kit, while keeping the OEM stuff in storage?
I have done some reading and research, but haven't come across a thread where someone replaced the R32 front diff with a R34 centre, and the video covering Motive garage and Andrew's 6-speed swap into his R32, but he keeps his 4.11 final drive ratios.
Edited by Diomedes
https://www.sau.com.au/forums/topic/483147-r32r34-rb26-front-diff-swap-out/
On 12/30/2021 at 4:15 AM, Diomedes said:
Yes, that is the most pain-free option. Was just hoping there was easy way to swap a few parts over and have 2 complete 3.545 ratio front diff/sumps.
Ever heard of anyone using the Tomei 3.692 Final Gear set?
https://www.gtr.co.uk/threads/wtb-pinion-and-ring-gear-of-front-differential-bnr34.572998/
You could try and contact these people to see if they still have it. I believe in the R34 if you want to match the gearing of the R32/R33 for better engine response the closest match is the Nismo final drive: https://www.nismo.co.jp/omori_factory/original_menu/final_g/index.html
The Tomei 3.692 final drive is an in-between between the OEM 3.545 that drops 120 kph to about 2800 rpm and the 3.916 that raises it to about 3050 RPM.
If you want 3.545, contact Neat gearboxes, they make them, may even have them on the shelf.
Thanks for the info, going to get in contact and see if the guys on the UK GTR site still have those parts. Could get lucky!
The Nismo final gearset looks nice, but also costs about 5 grand, without shipping 🙃
Have any experience with these guys? What is their work like? Any truth to their claims of making the OEM parts stronger with their treatments?
On 3/1/22 at 6:54 PM, Diomedes said:Have any experience with these guys? What is their work like? Any truth to their claims of making the OEM parts stronger with their treatments?
Shot peening is a process that has been around for a long time. Like I said, I’ve had my front and rear ring and pinion gear done. My diff and gearbox guy has been using Neat for many years and vouched for them. I’ve spoken to them over the phone. They were very friendly and informative. I’ve got the gears back and they look good, once my car is back together I’ll see how they hold up.
but as you can no longer buy the front ring and pinion gear, (other then second hand) it’s good to know you can buy new from there guys, they state the material they use to make the gears is a higher grade, therefore stronger and all their gear sets are shot peened.
I'd like to think that they've been looking into cryo treating also. I must ask them. Norwood Automatics have been cryo treating input shafts on Ford (and other) autos to help them hold up in Barra drag applications (and other high torque combos). Proven to help.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
