Hi Guys,
my car issues seem to be going from bad to worse and I’m hoping someone can offer some advice. I’m a Brit and have asked for help on the Brit forums but they’re not as active as they once were.
To save my thumbs I’m just going to copy and paste my posts from the Brit forum. I hope this isn’t considered lazy or rude:-
1st post…… For a while now my dash warning lights on my R34 GTT have been coming on. All of the them. When it happens the car runs like a bag of s**t. I pull over. Turn the car off and back on and the problem goes away. It doesn’t happen again for ages and then all of a sudden the dash lights up and the car is struggling. This has become more and more frequent and it’s now pretty much undrivable. I need to sort this out but don’t know where to start looking. A quick search around the forums and I’m thinking maybe coil packs but I don’t want to just change parts for the hell of it.
2nd post…… Ok the latest in the saga…….
I decided to replace the spark plugs and coil packs to eliminate them as the problem. I figured they were over 20 years old and could do with being replaced anyway. I’ve just been out to have a go at changing them but the car won’t start. It turns over fine but won’t fire. I had a replacement CAS here so have swapped that out but it still won’t fire. Pretty sure I’m getting fuel to the injectors as I can smell it! Any ideas?
Should the coil pack harness have a constant 12v feed once the ignition is on? Can I test this just by putting a meter across the + and ground pins? Is there a relay or something that should give the harness power once the ignition is on?
Any ideas/advice would be appreciated. I’m at my wits end.
Don’t know where to start looking really???
https://www.sau.com.au/forums/topic/483224-r34-gtt-won%E2%80%99t-start/
Are you sure you have the right spark plugs and coil packs? Since they are the thing you changed immediately before it wouldn't start. Also, depending what you unplugged, make sure everything is seated properly and any grounds were bolted back down again too.
I'm not certain about the 34 gtt setup, but assuming it is the same as earlier models you should find a pair of relays at the passenger kick panel, one for the ECU and one for the ignitiion. You should hear/feel them both click when the key is turned to ignition, and off again when the key is turned back to ACC (the ignition relay turns off immediately, the ECU relay turns off after a couple of second)
Thx for the reply Duncan. I didn’t explain myself properly. I didn’t actually get around to changing the plugs and packs. Tried to start the car to pull it onto my driveway and it wouldn’t start. Baffling. Will have a look for those relays when the sun comes up. Thx again.
So….. I’ve replaced all the coils and made sure I have a spark by fitting a spark plug to one of the new coils and cranking the engine. I’ve ensured I have fuel by removing what I assume is the ‘return to tank’ fuel line and cranking the engine. So I have a spark and fuel and the car still won’t run. Any ideas?
may be time to get an auto electrician out!
On 1/23/2022 at 5:11 AM, Bigpad said:
Oh. One thing I did notice while the car was in bits was that the throttle butterfly was fully open. I thought this was odd. Surely with no foot on the gas pedal the throttle should be fully closed? Or is this normal?
That's the traction control throttle body,  the one with the cable is the actual throttle body.
What does the ECU say? Does it get an RPM signal? Is it receiving the starter signal? Does it see acceptable battery voltage? Does it report any codes? Don't parts cannon a no-start condition, engine not starting is a pretty simple issue to debug. Either it's fuel, spark, or you have a mechanical issue causing excessively low compression.
How do I know what the ecu is saying? Is there a diagnosis I should be doing?
thanks for your comment. 👍
Ok I have it running. I did the plugs and coils and it ran. It ran like a bag of shit but it ran. Disconnected the MAF and it ran much better. Plugged the MAF back in and it ran like shit before cutting out. I think I have my problem. I will source a replacement and post the results.
Thank you all for your help so far.
It sounds like you figured it out but for future reference a Consult cable + Nissan Datascan 1 will be able to read out all of the data from the stock ECU or a chipped/Nistune variant of it.
If it is the MAF, have a look into resoldering the joints in the MAF - it's a super easy process and would be a quick/cheap fix if that's the source of your issues.
+1 get Nissan Datascan, it's about 30 bucks online. You'll need a consult cable - I just bought a China one from the Japanese ebay equivalent.
Well I bought a pink label MAF off a low mileage r33 spec 2. I’m told they’re the same? Plugged it in and started the car. It fired and ran just fine (I didn’t take it for a spin as it’s cold and dark and I haven’t done up all of the hose clamps or brackets).
However, despite the car seemingly running fine all of the dash lights are still lit up. I won’t know how she runs for sure until the weekend but I’d really like to get those dash lights sorted? Any help or advice would be appreciated! 👍
Also….. Is this what I need:-
and then download the data scan 1 software?
thanks again. 👊
  • Like 1
thanks again. 👊
https://nisscan.com/NDSI/index.php?content=supportedadaptors
Looks like it’s the right one but not sure.
thanks again. 👊
it will help if you have the software. I can't remember what happened everytime my car has thrown a code as I would usually just investigate, then fix, then remove the error with Nisdatascan.
That cable should work. The one I bought was just a random Chinese one (probs the same as that) which had no mention of compatibility with Nisdatascan.
You should note that there is some weird (USB) port thing with the adaptors and the software where it won't connect unless it's in the right USB port - you can google around to find the issue. I could only get the the adaptor to work on one of the USB ports on one laptop, irritatingly it's my largest laptop.
On 1/26/2022 at 12:44 PM, Bigpad said:
Ok thanks. I don’t have a tonne of laptops to choose from so wish me luck. Will take a lifetime to get here from China anyway. I can live with the dash lights until then as long as the car drives alright. Will find out soon enough I suppose.
You can check for codes in the meantime with a jumper wire.
On 1/26/2022 at 10:14 PM, Bigpad said:
Ok. Any advice on this? Wouldn’t know where to start. I will take a look around the forum.
thanks.
https://www.importavehicle.com/blog/check-engine-light-diagnostic-trouble-codes-for-1989-to-1994-nissan-skyline-gt-r
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
