Hey guys im new to the site and just seeking some information from the guru’s
soi have a s2 r33 factory gts25 sedan auto and long story short it’s become a 20e manual somewhere in its life now im converting it back, ive been doing alot of research and cant find if the flywheel from the 20e and the crank pulley from the 20e will fit the Rb25, and can someone confirm id need a pink sticker afm and also if any blue sticker ecu works for does it need to be specific. But im sorted for everything else
https://www.sau.com.au/forums/topic/483285-r33-20e-to-rb25-advice/
Flywheel is the same. I would not expect the crank pulley to be the same, and I'm horrified that the 25 you appear to have bought did not have one on it. You might just have to buy aftermarket.
Pink sticker AFM, check. ECU? You need one with the right part number. I wouldn't base decision off of sticker colour!
Cool about the flywheel cheers, it has a crank pulley on the Rb25 but there is a chip in it and and it will tear the belt so was hoping it would be convenient lol, i was meant to write blue plug ecu not sticker sorry
On 1/2/22 at 11:53 AM, PranK said:
The R33 did come with an RB20E from factory though I'm not sure you could bring one in. How sure are you that this is not a factory RB20E R33 with a badge?
Im in new zealand so we get a majority being a rb25de, but anyway my vin plate says rb25de and also the nz vehicle check site confirms stock rb25de, and it was a friend of mine that put the 20e in as he bought it as a rolling body then just put stuff he had laying around in it
  • Like 1
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
