As I went to paint my engine bay I had to remove the entire subframe and after looking at it for a little bit I then started to compare with pictures from others and their R33s, and mine looks different to theirs! What I mean is, the two faces where the engine mounts bolt up are completely in-line with the entire frame, whereas all other R33 GTST pics I've seen have the locations sticking further outward (towards the front) and are in-line with the forward-most bolt. I am attaching a picture of my subframe (LEFT) and a random R33 GTST subframe (RIGHT). My chassis is an ECR33 factory spec 2 GTS-T RWD. Is this some sort of oddball that left the factory or has the previous owner done a subframe swap? If so, I cannot imagine how an RB20/25 would fit inside the bay with the mounts situated close to 10 centimeters back towards the bulkhead.
Interestingly there is not a single thread or video talking about such differences so I am coming here for your advice.
https://www.sau.com.au/forums/topic/484135-r33-gtst-front-subframe-differences/
Gosh darn it, it's already been hell finding the missing parts for this car, now a subframe?! Will have to modify the mounts or the subframe then but I've got no idea how I would get the motor to sit like OEM. What a mess. 😢
So just a little update for anyone wondering, this has been 100% confirmed S15 SR20 front subframe. The entire rest ofthe front suspension is bolt on, control arms, R33 steering rack, hubs.
While I'm still looking for a GTST subframe I decided to make my own adapter brackets for the engine mounts, similar to the kit ISR sells but just the two mounts. I got the angles and distances right (the bolt hole centers on the adapter brackets need to sit 125mm FORWARD of the S15 mounting holes!) and the driver side bracket needs to be angled slightly more than the other.
However even with these, I cannot mount the custom turbo oil return line I have made for the HX35. The tube bends too far out and clashes with the S15 stock mount point. For this to work, a significant portion of that point will need to be cut out just so the pipe can go through it. Definitely not something I want to do.
Thanks for the offer, but I have already found a 25det r33 front subframe from the UK and it's already on its way to me. Even still, I am slightly worried the engine mount and bracket combination might be wrong. Why did Nissan make so many different  variations of parts on these damn cars?!
They didn't, really.
There's cars based on the R chassis (ie, Skylines Stags) and there's cars based on the S chassis (Silvias and Ceffies). And there's 4 cylinder engines that were mostly in the S chassis cars but sometimes turned up in the nasty budget versions of the R chassis based cars. And there's the RB engines that were pretty much exclusively in the R chassis cars.
There are engine mounts for each type of 4 cylinder engine in the S chassis cars (CAs and SRs). There are engine mounts for the 4cly engines in the R chassis based cars (probably the same as for the S cars). And the RB engines have a couple of different types of mounts - essentially the RB26 and all the others. You can pull an RB25 out of an R34 and drop it and its mounts into an R32.
This just keeps getting worse and worse. I'm at my wits end with this shitbox already regretting getting a Skyline. So I finally got the R33 25det subframe shipped to me from the UK and when I test fitted it what do you know IT ALSO DOESN'T FIT!!!
I'm throwing a tantrum here but rightfully so. Can someone tell me what in the world is the problem? Is the problem the fact that its a 20 block? I assumed their mounting locations and bolt holes are identical across 20/25/26? The rubber mounts themselves are not the issue as these are  BMW mounts 100% identical to the Nissan square ones that came (they were torn and unusable). Regardless, the problem is the surfaces are not remotely parallel to each other so it's not the rubbers.
I'm suspecting it's the metal brackets. The person I got them from said they were from an RB20DET and he assured me they would fit a 25 block also, which in turn would logically mean they would fit an R33 chassis?
Unfortunately I am out of funds for this kind of crap so tomorrow I will be trying to cut these where I have marked with yellow lines and welding a new gusset. My understanding is that the oil pan's bottom naturally is parallel to the ground and to the subframe so I'm using that as a guide. I don't know how wide the gap needs to be between the oil pan and the subframe either. What a headache 😖
OK, so firstly, RBs do not sit parallel to the ground in their engine bay. I don't have an rb25 in an r33 handy to check what angle that combo sits at. A possibility is that you have the brackets on the wrong side?
Secondly, I'm not sure it matters but the the mount brackets look like rb20 not rb25. rb25 look like https://www.jdmgarage.com.au/shop/engine/engine-accessories/engine-crossmembers-and-mounts/rb25-engine-brackets-pair/. Also note the mounts you are using don't have 2 studs at the subframe end but I guess that is your choice
I know the engine sits tilted towards the passenger side but the oil sump itself is tilted also and it looks to be parallel to the subframe and ground.  I also thought I had the brackets wrong way round so I switched them and the bolt holes did not line up at all, so that wasn't it.
After further research it appears I do in fact have RB20 mounts which are paired with the rectangular Nismo rubbers (40mm high), and the RB25 mounts come in two kinds, cast aluminium or stamped steel that are paired with the big circular rubbers like in your link.
None of this was really documented anywhere so hopefully this thread will shed some light for people in the future.
  • Like 1
Need to use the matching bracket to subframe.
r32 cross member to rb20 brackets
r33 cross member to rb25 brackets
r33/rb25 from memory have 2 types of bracket a steel and cast aluminium.
Project cars are fun aren't they.........
  • Confused 1
Last update to this, I'm probably the only person who's ever going to be in this pickle since I know you guys in NZ/Aus have an abundance of the right parts, but still I had to improvise because shit is just too hard to get and overpriced. Ended up modifying the RB20 brackets and they ended up really nice, close to OEM and the motor sits good in the engine bay. It may look cocked to one side but that's because I was supporting it with my jack at the rear of the sump. I am confident once I get the transmission on and its bracket, it will line up true. I even slapped the head on it and tested my rear head breather, it has plenty of clearance from the heater hoses and bulkhead!
312709579_3015904008555769_8129993717735555993_n.thumb.jpg.7ca19095ee21d8de3c5f38d45fc35c54.jpg
310980571_651384669725199_423654037759109634_n.thumb.jpg.ab9bc505467e56ad9053ce3237a86b85.jpg312705278_650613976709740_1390925090055558928_n.thumb.jpg.0040f57e61830c5a880e9d8a92ff403d.jpg
Edited by Neostead2000
  • Like 1
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
