Hi,
If using a race/serie damper :
- without AC, no relocation kit needed, it means that the steering pump pulley is aligned with the groove of the damper
- with AC, a relocation kit is needed, I would expect only to have a bracket for the AC compressor to move it forward however there is also another pulley and a bracket to move forward the steering pump which makes no sense ?
Obviously there is something I don't catch
Best regards
I'm pretty sure I've told you this all before in another thread. The deal is with the Ross race or gold series damper they are designed not to use ac and only has 2 pulleys standard, so where the ac belt would normally sit on the balancer that is a solid dampened area and then the power steering belt runs on the 2nd outer pulley in the factory alignment. Remember the ps is the very outside belt not the ac normally.
If you want to run ac they remove the outer damper ps pulley and put an ac pulley in that alignment then bolt the ps pulley on the outside of that pulley. This has the effect of moving both the ps and ac pulleys forward 25mm on the balancer, meaning you need the ac and ps relocation brackets to move the ps pump and ac compressor forward 25mm to realign with the balancer.
Relocation of the ps and ac forward 25mm means you cannot use the factory radiator fan anymore as it will hit - I measured my r32 and R33 GTRs for Ross to confirm that you can't run the ac relocation with a factory fan without hitting the ps. The 32 was somewhere around 16mm and the 33 was less at only 12mm. I believe the 34 is pretty much the same as the 33, but anyway none of the GTRs have 25mm + down there so it doesn't work unless you go thermo fans when relocating both ps and ac.
Hence why I ditched the whole ac relocate idea and went back to their current integrated trigger 800hp Tuffbond balancer as everything lines up like factory. Take their power ratings with a grain of salt - they are conservative on their power ratings and admitted themselves you can't actually rate a balancer in power. I'd suggest just get a Tuffbond unless you want to ditch the ac.
  • Thanks 1
13 minutes ago, GTSBoy said:
Surely this is just screaming out for either an electric AC compressor or an electric PS pump to solve the problem? Guessing PS pump the lower power/easier option.
To retain ps in factory alignment I'd say so for electric ac.
Obviously to keep ac belt driven you'd need electric ps and still need to relocate the ac 25mm.
My thinking is that mech driven AC comps use a couple of horsepower to drive them. So, if an elec AC comp was in some way super efficient and only used 1500W, it would still pull >100A on a 12V feed. I think the electric AC systems are from electric cars with much higher voltage supplies available.
I agree with electric aircon being a no go from a high electrical load perspective, so with the Race or Gold dampers that brings you back to:
-Having to relocate the ac 25mm to keep it mechanical then go electric ps pump to be able to use your factory viscous fan
-The undesired approach to relocate ac and ps 25mm, ditch viscous fan and switch to thermos or
-Ditch the ac all together, run factory fan and not relocate ps.
I couldn't be f**ked doing any of those options when the Ross Tuffbond is factory alignment and will be fine unless you're looking at 700kw + or stupid 10k rpm stuff.
Thanks for all your reply !
I would prefer to keep the PS stock and elec AC is not really possible as you mention
@BK, indeed you already make some explanations but I didn't understood the purpose of the kit, now I do thanks to you
"If you want to run ac they remove the outer damper ps pulley and put an ac pulley in that alignment then bolt the ps pulley on the outside of that pulley. "
I didn't know the outer pulley was screwed to the damper itself !!! this is now 100% clear !
Couldn't we run the AC and PS on the same belt ? (so we need only to relocate AC )
Assuming ratio are ok
find in attachment some pictures of my r34 gtr
It's a lot of load for the one belt to have to pick up at the crank pulley and it would be difficult** to arrange the two pumps so that you go enough wrap on the crank pulley to do it.
**Potentially impossible to transmit sufficient torque even should you be able to locate them so that you can get the maximum wrap around the crank pulley.
  • Thanks 1
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
