So yesterday, giving the car an once over before tomorrow night's event I noticed something rather alarming.
The Ross PS idler actually fouls the AC compressor belt.
You can see the scoring on the lower belt. I tried using the RB26 spacer included in the kit but it ends up only supporting 2/3s of the belt and the other 1/3 overhangs. Either approach is going to be good for tomorrow night so I ended up using a 4mm or so washer and packing out the bracket to move the idler forward. Seems clear everything now, however the idler bracket bolts are now really close to the PS belt itself. (Didn't take photos of this, finished up late night and just wanted to go to sleep).
I've contacted Ross Performance and hoping they are able to machine down the RB26 spacer, here's hoping they reply at all lol...
I'll take a photo of what I've done tonight when I'm back home.
It seems they didn't design this for RB25 motors with AC, or thoroughly test fitment on all combinations and permutations.
Then again their target market are heavies.
Added spacers to clear the AC belt and had do remove the spring washers on the bolt side to allow it to clear the PS belt.
Fun times, not. Piece of shit car, always spannering the lump of shit before events.
There's about 8mm of clearance to the fan blade, camera angle makes it look much closer.
Will trade for a F80 LCI M3 if anyone is keen?
  • 5 months later...
So update, Ross said they would review it and they never got back to me.
After a couple of follow ups, nothing. Even tried messaging them on IG and nothing. Guess I'm not a big player (spend heaps) or have any social presence.
They're happy selling products that semi work (works great if you don't have A/C) and when you try to provide constructive feedback you're met with radio silence.
Guess it will just have to live with the spaced out bracket using washers - better than nothing, just annoyed I bought something that was supposed to be engineered to fit.. Oh wells, shit box Nissans.
It would seem to me that if there is sufficient meat on that idler, then machining a couple of mm off its diameter would help? Or, per my original suggestion, can you do something about the alignment of the mount to the front of the engine to lift it up vertically a little? Or a little of both?
Or, a smaller diameter idler to replace that one?
Both your solutions are valid, for now the spaced bracket works and when the car is due for any kind of belt change/timing, crank trigger kit (won't be using Ross after this experience), etc. I will look into replacing the idler OR skimming off parts of it.
Sigh... I hate modifying cars now.
  • 1 year later...
10 minutes ago, chamama said:
I just had similar issue on my r34 gtr where the pulley bracket is hitting the ac compressor belt. Although I have the Ati damper on.
Did you try to get in touch with Ross? They will start to reply then ghost you completely.
Even though I was super polite and understanding.
Guess I'm not some famous tiktok YouTuber, hence they don't give two shits.
How much is it pushing down on the PS belt? What if you slot the top hole in the mounting bracket so it can rotate toward the PS pump and raise the idler enough to get it off the AC belt.
In my experience with some mates drift cars, the belt gets flicked off on the sudden decrease in crank pulley speed on the limiter or downshift in a dog box. We came up with a good fix for the 2J using some Mazda timing belt idler that was just resting on the belt and stopped the belt coming off on some cars that were chronic for it.
Thanks for the advice. We are try to shave off some material from the bottom of the bracket to see if that works. I ideally wouldn’t want to slot the holes cause that would have the chance to move I think
  • Like 1
  • 3 weeks later...
11 minutes ago, Findlay said:
Similar experience with Ross pulley. Can't recommend.
Useless lot aren't they?
Releasing stuff on the market that doesn't do what it's supposed to do without you stuffing about with it and spacing out the spacer lol.
FFS.
51 minutes ago, chamama said:
I think I will try out Frenchy’s power steering kit. Looks like a better solution.
I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
I just put one on my car, nice bit of gear. I've had an astra pump on a car before and wasn't a huge fan, need a way of controlling the pump  speed so it doesn't drive like a '70s Valiant
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
