Hi All,
interested in purchasing the crow cams below but out of stock. Have found a kelford cam but want to know how the kelford cam compares to TX2 or TXM.
Kelford cam specs are:
cam 274 or 226-F
i need to know the duration at 0.50 of inlet and exhaust like crow cams, kelford cam only has valve lift duration at 1mm.
could someone please work it out so I can have the specs like the crow cams.  Need to to duration at 0.50 of intake and exhaust. TIA
Edited by VL_Turbo
Oh. For f**k's sake. 50 thou is 1.27mm which is so close to 1mm that you can just pretend that it is the same and the worst that can happen is that the duration measured at one of them will be a couple of degrees different from the other.
The guy at Kelford probably should have heard about measuring duration at 50 thou because he works for a cam manufacturer and 50 thou was the standard for a million years, but it is totally understandable that he doesn't know because he is likely <30 years old, lives and works in a country that has been metricated since before 1970 and will only be using SI units in their manufacturing process because they are civilised and not trapped under the weight of 300 years of 'Murica f**k Yeah yeehaw freedom units like Crow f**king Cams is.
  • Like 3
  • Haha 2
I like the way crow cams can't spell medium.
Out of curiosity what exactly are you comparing the cam specs to? Each other or some calculated desired valve timing events you have already figured out?
How much piston to valve clearance do you have to work with?
I just thought of this & thought I’d let you know, the good news is the above camshafts do exist, but will they snap?
get the specs off the Kelford “turbo” cam from golbeys & regrind your genuine one to those specs. clivecams, surecam & Marshall custom cams do reginds.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
