Hey all
I just purchased a S1 Rs Four V from Japan and have a lot of questions as these cars are beyond scarce on this side of the pond.
thanks in advance for the help I’m going to get!
cheers
  • Like 1
https://www.sau.com.au/forums/topic/484742-newbie-in-the-usa/
Nice, you probably won't come across too many others at the local Woolies.
Unfortunately the first thing you should know, is that while they have pretty much the same potential as any r chassis skyline, they are a real slug standard.
  • Like 1
They seem to be getting scarce on this side of the pond too!
Mine is modded to what I would consider "Stock Plus", basically sharpened suspension, shift kit in the auto trans, slightly larger turbo and an ECU resulting in 200awkw. Gives it more pep without being too laggy, and also not on the brink of snapping something. Ive owned it for 15 years now, myself among others here can give you a fair few pointers on what should be done, and what shouldn't be done.
  • Like 1
7 hours ago, Murray_Calavera said:
Welcome!
Looking very tidy, good find :)
Cheers mate.
a bit of paint repair and she will look better!
I’m okay with slugs when they look this cool. I grew up in NZ so I remember these cars when I was growing up. I have yet to see one on the road in the US.
I ordered blitz ZzR coil overs from Japan yesterday, and now the search is on for a set of 17 or 18 inch wheels (the 15s that are on it look like lawn mower wheels)
thank you for that! I will take all the advice I can get. I do need help with wheel fitment. I rear on here that several rear cradles were used. I was looking at 17x9 + 30 but I rear that the rears stick out too far so my search is starting over again with maybe an 8 or 8.5 instead.
1 hour ago, GTSBoy said:
Fixed that for you. But yeah. Nice Volvo wagon, either way.
Re fitment, I have R34 gtr wheels on mine all round, they are perfect at the front and stick out approx 1.27cm at the rear (which I just live with, the wheels tuck in under compression).
Funnily enough though, if they are factory wheels they are probably worth keeping in the shed so you can put them back on when these are billion dollar classic cars
I’m not sure if they are factory or not. The look like BBS with the spin off center cap. They also dual lug pattern.
I would love to have r34 wheels but they get rather pricy over here and most are scuffed.
I was hoping to find the a good offset for a square setup.
many offset advice would be appreciated. Looking for a 17 or 18 and lowering the car enough to make it not look weird. I don’t want it slammed on the ground. This will be my daily driver more than likely
Give some thought to doing a big suspension and brake overhaul. I did that about 11 years ago and it totally changed the feel of the car. The steering was much sharper and the car tracked straight over bumps in the road, whereas before it was a wandering mess. It might take you a couple of months with the car on stands, but it's given me a decade of rewarding results.
Given the age of the car, you could probably assume the following are stuffed:
All suspension, subframe and steering rack bushes. I used Superpro polyurethane replacements.
Inner tie rods and outer tie rod ends on the steering rack.
All ball joints, 2x for each front wheel (on the lower control arm). Same as skyline GTR. Rear suspension has 1x ball joint.
Certain suspension arms can be replaced with adjustable units, like the caster arm, and upper control arms for the front suspension. This allows the alignment to be set more accurately than those crappy eccentric bolts that are standard.
Having everything stripped down is a good time to get to things like the driveshafts. While they are very good quality and long lasting, the boots inevitably crack and lead to the contamination and destruction of the inner joints. Over the past year and a bit I've replaced all 4x driveshaft boots (ie all 8x boots).
This gives you a really solid base to then start piling on the mods.
Thanks for that!
im already trying to source a lot of those suspension parts but not much luck.
3 out of 4 rear suspension control arms are the same as a S14 so that makes things just a bit easier.
I’m a Nissan mechanic by trade so I do not mind doing the labor and actually enjoy it.
I will keep looking for all the bits. I have the coil overs, inner and outer tie rods coming from Japan. Brake caliper rebuild kits coming from the United Arab Emirates. Slowly I’ll have everything I need hopefully before the baby comes (in 2 months) or it will go on the back burner
  • Like 1
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
