Hi there,
so i recently took off the intake manifold on my R32 GTR to fix a coolant leak. replaced all the coolant hoses with silicone ones, all new HKS metal gaskets + some extra hylomar sealant around the throttlebody ones, new oem vacuum hoses and clamps as well. Everything went pretty okay until going on test drive. Somehow car hardly makes positive boost now. Obvious thing to think -> i f**ked something up on reinstallation, so i pressure tested the manifold this weekend, see attached video... never done this before but to me that pressure loss seems pretty much normal over the TB's, valves, and so on isnt it? Engines overall in unknown condition, unopened in my ownership. No other obvious hissing noises, only thing i found is a slightly leaking PCV valve, that must have leaked before i worked on the manifold tho and it did make boost before. new one is on order anyways.
turbo spool up is not delayed or anything... got the car with some probably old af HKS turbos that always kicked in between 4.5-5k, thats still the case it just doesnt go over like 0,2mmhg on the stock boost gauge anymore. idle is smoother than ever. also tried spraying break cleaner around the mating surfaces of the intake with the car running, no reaction.
I dont have a boost solenoid anymore, dump pipe goes straight back into the intake with no restriction. no external boost controler or anything, stock ECU afaik, wastegates work like theyre supposed to according to the manual when pressurizing directly onto them... should make ~1bar.
Any ideas? The car has to be f**king with me if the problems not actually on or around the manifold/ air chamber area as i didnt do work on anything else and it ran just fine before... i just cant seem to find it. i was thinking maybe some electrical error but the stock ECU has no more ways to mess with boost control in my setup has it? only thing it could do is pull timing which generally shouldnt affect boost, right?
opinions and input on what to do or check next are appreciated, thanks in advance
Max
https://www.sau.com.au/forums/topic/484804-rb26-boost-leak-limp-mode/
First, if you deleted your boost solenoid what is your vacuum line routing for the wastegate? I have personally seen people do the exact opposite of what they need to do to run wastegate boost when deleting their boost solenoid so this is an important question. Also I recommend checking for boost leaks starting after the MAFs.
Second, what do your fuel trims look like? Long term and short term. If it's off by more than a few percent you still have problems.
Third, have you inspected the turbos? Turbo failure can start with not making boost.
For the solenoid: All i did was remove that cause it wasnt opening anymore, just connected the two lines directly so it should run at "no-restrictor" boost all the time.
What do you mean by fuel trim? afr? cant tell that, stock ecu, no external gauge. Judging by the plugs car does run a bit rich, didnt mess with that tho and as stated it did make boost before. forgot to properly tighten a clamp at the fuel tube under the plenum, fixed that and still same issue.
Didnt check the turbos yet, if one was broken it wouldnt make boost at all as it would leak through the broken one, wouldnt it? Or at least should have a noteable delay in spool up...
I haven't measured the wastegate solenoid duty cycle but a local near me had something similar going on with his RB26 where the previous owner looped the wastegate line to atmosphere. It pegged the stock boost gauge. Once he capped the wastegate line so it no longer vented to atmosphere he ran wastegate boost. If you have any doubt that your ECU is not tuned for the turbos your engine is running you should run wastegate boost.
The factory ECU has narrowband O2 sensors. It doesn't know anything other than roughly stoichiometric but it will adjust how much fuel it injects based on that information. If the short term fuel trims to hold it around stoichiometric are reliably offset in one direction that feeds into the long term fuel trim. If the long term fuel trims out are of spec that will tell you that you have some kind of running issue like unmetered air leaks.
One broken turbo can lead to the engine make some boost. It will be noticeably less but still some boost. Also, if the turbo bearings let go from a boost leak you need to stop driving it sooner than later. Turbo failures often cascade into whole engine failures.
Thanks for your input mate. the solenoid is only a "safety feature" that doesnt do much after all. it wouldnt open on my car which led to boost staying at 02-0,3bar, just bypassing it leads to "stock" boost 0,7bar with restrictor, about 1 bar without restricting the airflow back into the intake pre turbo (blue tube in diagram) or am i dead wrong somewhere here?
i wouldnt focus too much on WG or fueling anyways tbh, as mentioned didnt do anything to those systems and it ran for the last ~4 years like that without noticeable issues. oil always looked fine, no smoking, overheating or popping... i feel like it has been running healthy enough with the setup the japanese dudes before me installed.
Whats your opinion on the pressure drop off on the manifold test?
guess ill check turbos next, then pressure test the system from MAF till plenum, maybe the rubber hose from IC to that metal piece under the battery tray got loose from massaging the hose between that and plenum out.
The R33 GTR manual specifies 8.56 psi minimum to crack open the wastegate, purely spring pressure. It's not significantly different from the R32 GTR. Something was already wrong, it's just more wrong now. A 0.3 bar spring would only allow for a theoretical max of something like 0.6 bar boost.
My mate has an R33 with the exact same boost levels when he forgot to hook up the solenoid. The spring opens at the pressure the manual states, you have tot take into consideration its not just boost thats working the gates but exhaust backpressure too.
Exhaust backpressure alone is not going to make you lose half of that spring rating. Anyways, if you really do have some HKS turbos in there you don't want to be running a lot of boost regardless. It's not that hard to max out the factory MAFs.
Edit: We've had this discussion before two years ago, my answer still remains that you have some kind of mechanical issue. If you had a boost leak before papering over it by running max bleed on the wastegate vacuum line isn't a good idea.
  • 1 month later...
Update: Took things apart again, checked all the air chamber hoses, pressure tested the WG control line, tested the manifold with smoke+2bar, soapy water, pressure alone - nothing. No hissing, no bubbles, no smoke visible, WG line holds pressure forever, gates open as they should at ~0,6-0,7bar when putting pressure directly onto them. Also checked the BOV line, properly hooked up, gets full manifold pressure + and -. A bit of blowby thru crankcase, thats all.
What i found out is that the stock gauge is lying, cars actually running at 0,6-0,7bar with unrestricted WG bleed tho, yet the actuators are operating, see attached video of a short pull.
I dont get it. Any more ideas?
I didnt paper over anything. i got the car running without restrictor, +-1bar, same turbos, same ECU, same fueling system, same everything and it ran fine like that for the last couple years. I LOST a bit of pressure somewhere while taking off and reinstalling the plenum and cant seem to find out where, thats all.
0.6 to 0.7 bar is still low if you've bypassed the solenoid and you're venting the wastegate vacuum line to atmosphere. Have you checked how much exhaust backpressure you have?
Nope, think i got it tho.
Running the wastegate bleed line all open or completely closed (where the solenoid wouldve been) only does like 0,1bar difference in boost. also checked the bleed pressure in the line itself -> equally like +-0,1 bar.
My best guess at this point is that the hardline part under plenum smh mustve got mangled and is blocked. Ironically enough these lines are the only ones i didnt touch or renew while working under the plenum.
Guess ill bypass the hardline part now and go plenum -> T-Connector -> (1) hardline to WG behind engine and (2) vent line back into intake.
On 9/16/2023 at 7:28 AM, Max32 said:
Update 2: That wasnt the problem either, hardlines completely bypassed and boost still wont rise over 0,6ish bar.
Any more ideas somebody...?
Have you inspected the turbos at all? I had a friend with the same issue on a different car. In the end it was turbo failure. Check the compressor and turbine blades carefully for damage, they have to be extremely close to the housing in order to actually generate boost/spin a compressor and any little thing can damage that "seal" and cause your symptoms. If you have one turbo functioning properly and the other isn't it can cause similar behavior as one turbo effectively turns into a boost leak because they're joined together at the twin turbo pipe.
Sure, i just cant believe thats the issue tho. as i said it started right after i messed with the plenum and what not, hot-side failure somewhere inbetween that would be the weirdest coincidence.
i did some research on the turbos and judging by the compressor housing they look like old HKS GT2530s... dont know if they even still have the ceramic exhaust turbines
Also, checking the front turbo is not that useful. Usually the rear turbo is first to blow up.
  • 9 months later...
Hey Max32, what are your results on this issue? Did you ever fixed it? I am in the exactly same situation like you. Waterhose was cracked and i removed the Plenum, throttle valves. Air Chamber and replaced all waterhoses and vacuumhoses. After reinstall and putting all in the exact same placed back together, i cant boost over 0.7 bar. Besides that, the car is just fine - no issues.
Have no boostcontroller and always removed the restrictor for gaining 1.0 Bar with Steel Turbos. But now its like and it feels like the restrictor is back. I have no clue. All was fine before. Also tried to bypass the solenoid (thought it was blocking or something) but there is no change.
regards
Remember our cars are 30+ years old so expect the rubber bits to leak. I'd go around your engine bay with a can of "start ya bastard" or similar and look for leaks.
FYI I got my car 10+ years ago with the standard boost restrictor in place, I removed it when I got it and the car never had any issues since (besices a leaking manifold gasket).
tl;dr- Look for leaks before proceeding.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
