I keep going back and forth on this and just wanting some opinions.I currently have a set of r34 (im pretty sure) sumitomos on my stagea rs4 daily/street hooning car that's mostly stock. They're nice and quiet with decent stopping power but I have felt them fade a bit doing some spirited driving coming down the mountain.
recently I found a full set of z33 brembos with stock pads, rotors, and lines for a really good deal and picked them up.
Is it worth swapping to the brembos or should I sell them and buy slotted rotors, better pads, steel lines and fresh seal kit for the sumitomos? Wanting to get around 450hp with some light track use in the future.
https://www.sau.com.au/forums/topic/484812-r34-sumitomo-vs-z33-brembo/
3 minutes ago, MBS206 said:
I would start with a complete bleed of the brake system too with fresh brake fluid.
Most fade people get on the street is either from pads not suited to the driving, or old fluid that isn't happy anymore.
The fade only happens going downhill on the togue after a few hairpins. But my pads probably have 2mm left in the front so no matter what I'll be swapping those and doing a fluid change
The Z33 Brembos use a 324mm disc as well, would be much better than the 310mm R34 GT-t Sumitomo setup.
I run the Z33 Brembos on my shit box and it seems to stop well at Sydney Motorsport Park's GP Circuit. I have only 437kW, so not huge power but can happily do 2x hot laps before experiencing any brake degradation. Currently using Intima RS pads (superseded model).
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
