I have an R34 one in my 32, but that is because the other end at the fuel door broke (plastic in 32, steel in 34).
Is the 2nd pic a temporary fix?
I think it is repairable, I'm not sure of the method but it would be worth either checking around or getting an instrument repairer to look at it
Some advice, i realized that the cable broke, because there is a big ass washer on the seatbelt thing and it was squeezing the cable causing it to have extra tension. Make sure that big washer isn't sandwiching the cable.
  • Like 1
2 hours ago, weikleenget said:
Yeah he tried a fix but it broke again. The cable is the exact same length and connection between 32 and 34, in other words no other modification is needed? The 34 cable is available for sale
The R34 cable is longer but it doesn't matter, because as long as the ends are in the right place there is just a bigger loop in the rest of the cable.
I see a worldwide shortage of 34 fuel door release cables starting very soon. Australia's stock already sold out 3 months back
I'm confused honestly by this, as far as I can tell isn't this basically all repairable using off the shelf bicycle/motorcycle components? Other than the inevitable injection molded plastic bits. The T end piece is a very common bowden cable part that just requires the right crimper to replace, etc.
  • Like 1
thanks Josh, that is exactly what I was trying to get at, I just wasn't aware of the term or method.
Please fix this one instead of reducing the parts remaining in a small pool!
Edit: sorry, to be clear, the fuel release end in the 32 is a plastic catch in a plastic thread which cracks....I could not see a practical way of fixing that beyond 3d design and printing which is outside my skill set
  • 1 year later...
I'll bet the 34 one does work in a 33 if it worked in a 32, like a throttle cable the only things that matter are the connection at each end and the cable not being too short (too long is OK).
The good thing is the 34 is sintered metal while 32, and I think I saw 33) are plastic ends so likely to last longer.....if you can find one,
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
