I have an R34 one in my 32, but that is because the other end at the fuel door broke (plastic in 32, steel in 34).
Is the 2nd pic a temporary fix?
I think it is repairable, I'm not sure of the method but it would be worth either checking around or getting an instrument repairer to look at it
Some advice, i realized that the cable broke, because there is a big ass washer on the seatbelt thing and it was squeezing the cable causing it to have extra tension. Make sure that big washer isn't sandwiching the cable.
  • Like 1
2 hours ago, weikleenget said:
Yeah he tried a fix but it broke again. The cable is the exact same length and connection between 32 and 34, in other words no other modification is needed? The 34 cable is available for sale
The R34 cable is longer but it doesn't matter, because as long as the ends are in the right place there is just a bigger loop in the rest of the cable.
I see a worldwide shortage of 34 fuel door release cables starting very soon. Australia's stock already sold out 3 months back
I'm confused honestly by this, as far as I can tell isn't this basically all repairable using off the shelf bicycle/motorcycle components? Other than the inevitable injection molded plastic bits. The T end piece is a very common bowden cable part that just requires the right crimper to replace, etc.
  • Like 1
thanks Josh, that is exactly what I was trying to get at, I just wasn't aware of the term or method.
Please fix this one instead of reducing the parts remaining in a small pool!
Edit: sorry, to be clear, the fuel release end in the 32 is a plastic catch in a plastic thread which cracks....I could not see a practical way of fixing that beyond 3d design and printing which is outside my skill set
  • 1 year later...
I'll bet the 34 one does work in a 33 if it worked in a 32, like a throttle cable the only things that matter are the connection at each end and the cable not being too short (too long is OK).
The good thing is the 34 is sintered metal while 32, and I think I saw 33) are plastic ends so likely to last longer.....if you can find one,
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
