Ik ik… I have googled and tried different remote tuners to look at the maps to see if they can spot an issue because I cannot find a physical issue, even Haltech looked at them, AFR’s are good everything is acting as it should supposedly. I’ve spent over a year trying to dissect this problem and countless nights. This car WILL NOT rev over 4.5krpm. I just want to finally drive my car. Everything that could be replaced, has been replaced atleast twice. Coils are new and been swapped twice, the CAS is brand new, injectors are new and fuel system is full AN with no leaks and steady pressure. Fuel pump is ran on its own relayed circuit, steady voltage. I have tried 2 separate new map sensors. All protective measures have been turned off in the ecu as well so there is no limiters to hit… Ect ect. You name it, it’s probably been gone over.    What Am I Missing!!
-Haltech platinum pnp, onboard map or Haltech 3 bar(have both), full 3in exhaust, pulsar gtx3076r, 1000cc id injectors, aeromotive afpr, fmic, ffi manifold, 44mm watergate, Haltech boost solenoid….All the standard stuff…
pretty average setup. Please help
Edited by Spooly240
Added details
Valet mode? Do you have a aftermarket alarm
Does your ECU have valet mode?
I know some cars and alarms have them and you need to do some switch toggling to activate and deactivate
If you do have an alarm google the brand and look for how to activate and deactivate it
Or, as stated above, Cursed by a wandering gypsie, built on a pet cemetary, etc.
@GTSBoy All the above you mentioned have been checked. Me and a couple others went through the timing a few times and no issues with mechanical or ignition timing, the exhaust is straight through, no cat. Ive set and checked timing of the CAS a handful of times ik the cas can’t be out or the car wouldn’t run at all. The car runs perfecctttt, except right in that 4500rpm zone
@morboost speedo is no longer in the car, I’m running a powertune digital dash, and all anti lag and other features are all off.
@The Bogan I believe the Haltech platinum pro does not have valet. I mean you could technically run a switch to switch between tunes but none of that has been done. Also no alarm is in the car at the moment.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
