On 22/03/2024 at 7:29 AM, Duncan said:
Welcome to SAU....how long until you get to see the car?
Hi Duncan,
I picked up the car in August last year.
Just swapped out the old suspension for some basic BC's and started driving it.
https://www.sau.com.au/forums/topic/485363-new-to-sau/#findComment-7988093
8 hours ago, Dirtyrider00 said:
Welcome
Thanks GTSBoy for reporting this lowlife.
On investigation this is another scammer. They have sent 2 PMs to people as follows:
To Marzoum - Hi Mate, a member of the forum have some BNR32 Front driver side (right) abs sensor for sale. He goes by "oktaytrz" here, you can reach him at [email protected]
To cabramatta - Hi Mate, a member of the forum have some R34 GTT Manual Gearbox for sale. He goes by "oktaytrz" here, you can reach him at [email protected]
Well constructed really, because oktaytrz is a long term, previously active but now inactive member, and by redirecting them to the scammer's email instead of the real members email it may well be effective phishing.
Please be cautious of any PM directing you to an off forum email, of course we have no visibility of what happens outside the forums.
https://www.sau.com.au/forums/topic/485363-new-to-sau/#findComment-7988369
Seems to be not the first time for that guy @Duncan. Was successful before as well. See the below post where he was redirecting to the same email. I like to believe there is a special place in hell for people like that.
@PranK put in a post limit before messaging but looks like that doesn't really help. Just invites cheap posts on welcome topics. Not sure what can help here. Maybe a warning when opening private messages?
https://www.sau.com.au/forums/topic/485363-new-to-sau/#findComment-7988372
Yeah I had mentioned to Duncan that limiting messages is a little tricky but that this has happened again I'll get this done in the next few days.
And yes @soviet_merlin I'll put a warning banner on the top of the messages screen, nice idea! :thumbsup:
https://www.sau.com.au/forums/topic/485363-new-to-sau/#findComment-7988375
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
