Hey guys just wondering if I can get some clarification on this refrigerant pressure sensor wiring. I bought a 3 pin pigtail to wire in a refrigerant pressure sensor and I just want to make sure I'm reading the schematic and connecting it properly. My ECU doesn't have anything in pin 57 so I put a pin in and ran it to the WHITE wire on the pigtail. Then pin 48 to the BLUE wire and connected the GREEN wire to ground. After doing this I went for a drive and my CEL came on. The car also had jumpy acceleration. Since pin 48 is also the power source for the throttle position sensor I'm wondering if I messed up or reversed the wiring somehow. Any help is appreciated, thanks!
Well, what you've done looks correct, but only if the sensor has the same pinout as the stock sensor. If it's not a stock or stock equivalent, then there's some chance that you've got two or more of those switched, which could be anything from non-damaging to let-some-smoke-out.
  • Like 1
24 minutes ago, GTSBoy said:
It's not the connector I'm concerned about - it's the sensor itself. The connector is agnostic - doesn't care what you're doing with it. The pins on the sensor need to match what the ECU thinks it's pins connect to.
Right, sorryー I'm an idiot, of course it's the sensor not the connector 😳 So I just did some digging and found out the part number I was given by someone at Nissan is actually the wrong part number....so obviously it doesn't work properly and I probably fried something in the process.
With that diagram you posted first, often the adjacent section of the workshop manual will confirm what the wires actually do as well. Of the 2 wires between the sensor and ECU I assume 1 is power supply, probably 5v and the other is signal to the ECU, but it isn't possible to tell which is which from the diagram.
Unfortunately if you have grounded the ECU 5v output by accident you might have damaged the ECU (or if you are lucky just popped a fuse).
Why does the ECU not have these wires, was it a non-AC car or a different ECU to factory?
  • Like 1
It's an engine swapped car that I knew about when I imported it. What I didn't know is that whoever swapped the engine didn't swap the harness....so it's an RB25 with an RB20 harnessー a complete shit-show to say the least. For the most part everything runs fine (until I tried to hook up this sensor 🤦‍♀️) I feel like the ECU is fried due to the incorrect part number I was given but I'm able to get another one from a friend so once I order the correct refrigerant pressure sensor it should be ok....
  • Like 1
And double double triple double check the pins on the sensor, making sure you understand the orientation of the connector view on the diagram and hopefully the pinout on the sensor itself is documented on its paperwork, for comparison and triple double quadruple double checking.
  • Thanks 1
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
