Anyone know anything about a r34 350z lsd diff conversion?.  I have 350z lsd conversion layin around and thought about chucking it in my r34 I got all the offset adapters but am having trouble figuring out on how to get a speedo reading. Any help would be appreciated thanks
(I have both speedo sensors from r34 and 350z)
https://www.sau.com.au/forums/topic/485572-r34-350z-lsd-conversion-speedo/
3 minutes ago, GTSBoy said:
R34 vehicle speed sensor is in the gearbag.
hey man nah I’m sure they get it from the diff like the s15 my speedo went out in the past and I just replaced the sensor in the diff and everything was working again
(idk if this helps but I got a HR34 sedan)
OK, that explains it. The auto NAs are not something that even enter my thinking 99.9% of the time.
If you put a small turbo box into it then you could use an appropriate speedo sender in that and connect to the dash. The caveat there is that I have no idea if the calibration of the dash would be even close to correct. It might not even work. I do not know how the diff mounted speed sender works, and there is every possibility that it is different to the signal generated from the gearbox mounted sensors.
I would suggest hooking an oscilloscope up to your speed signal from sender to dash and recording the waveform at some known speeds.
yea that might be an issue the sensor in the diff is for both abs and speedo same with the 350z diff except the 350z diff has 4pin connected while the r34 one is 2 pin.
One thing you may be able to leverage is the fact that the R34 N/A has the same setup as a S15.
The S15 also is a car that gets 350Z diff swapped, so they will also likely have this problem.
The caveat of course is it's possible the dash is different between the R34 NA and the S15, but the subframe/sensors/axles/diff setup are the same.
I can't remember now as it's been too long, but I don't generally think people need to swap dashes between the N/A dash and the turbo dash when they do things like change the gearbox out, turbo their car, manual swap it, it's just not something I've seen mentioned so this could be compatible.
  • Like 1
  • 1 month later...
Having seen a 350z diff swap I wouldn't do it, they don't really fit because the diff mounting ears are higher up the case and the diff sits very low in the sub frame.
I looked at it but am getting 3.5 gears from Neat instead.
Edited by Komdotkom
Put it in about 2weekz ago I haven’t heard anyone do it before but all the parts just fit right in the diff sits quite low and the diff ratio is pretty f**ked I thought I bought a 3.6 but I ended up with a 3.3 I believe😭
looking into finding something closer to the original ratio to the r34 diff (4.1)
also having trouble trying to get somewhere to get a speed reading as the r34 sedan gets the speedo reading and abs from the diff
update i did some test and think the diff has a 3.3 ratio i also took it out and readjusted the offset bushing on the subframe which made the diff sit higher about the same as the stock r200 r34 diff.  (P.S : you'll need an 18mm spacer fabricated from your driveshaft to diff flange as there is a gap i think it might be unnecessary for some skylines
I have a HR34 which is also a 4speed automatic which is now slower with the smaller ratio as the OG ratio is 3.9. ill see whether or not ill change the ratio after i do my manual swap. I am putting in a RB20det gearbox in it honestly hoping the gearing will be better if not ill probably steal a crown and pinion from a g37 or some with the 3.9 ratio
After some inspection it seems that the diff has a metal gear near the diff flange with the sensor slotting in a hole that hovers above it. I believe it is some sorta Hall effect sensor which reads the amount of rotations of the pinion to calculate the cars speed.
the 350z also uses this mechanism on the diff except it has it on either one of the diff flangers and 2 seperate speed sensors. I soldered the wires and i still have no reading.
might just go with the gps speedo at this stage haha
Yes, well, that wouldn't work even if the sensor was compatible, as the pulse rate would be all wrong.
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
