Factory oil temp sensor in a RS4V without gauges?
What happened to looking for a cheaper bolt on turbo? I don't think you'll find anyone here (that isn't American) that will recommend this turbo... its absolutely crazy money for what you get. -
hybrid is stock turbo frame with custom billet wheels and internals
Ok thank you...maybe the term "hybrid" is used here to describe what you said And any other turbo that is "bolt on"? Iam kinda leaning towards this new HKS: https://www.rhdjapan.com/hks-sports-turbine-kit-gtiii-rs-skyline-er34.html It is bit expensive but it should be enough for my power now and in the future 🙂
By TurboTapin · Posted
It's a 6boost, T4 twin scroll, twin gate. Have issues been popping up with the Artec's? -
94AKI so I believe it's roughly 100-101ron. We don't have E85 at the pump in Canada, so it's either race gas or water methanol injection. I run a 50/50 mix. Since 4$ a liter race gas is expensive, WMI is often used here. I'm currently running a constant pressure system with direct port nozzles. We tend to see roughly the same from WMI as we do on E85 race gas. Fueling is not my issue. Have you seen anyone run more than say 520kw(~700WHP) on a mainline limited at 7600RPM on a 6466? This is the sort of comparison I'm looking for. If I could rev it up to 8500-9000rpm, I believe I would be seeing the HP I was originally expecting. Thanks.
