  • Replies 330
Righto!I've named all the various photos taken today,and they're right to go...Except they're all too "big".Anyone got some suggestions for a compu' dork to compress them before I go and attempt to post them up(note:attempt...)Oh,yes:is everyone OK that I haven't had time to "blank out" their numberplates?Any one who'd rather NOT see their 'plates(or even car)across cyberspace,drop me a line and I'll change things.Or PM me your email address if you want these forwarded on.Once I've worked out how to get these piccies small enough,I'll put my car on as a trial post...
Top day all round!J
ive got my pics up, i think they should work, they should be here if they dont work, let me know an i ll try to fix them, oh and i better add, they arent professional style by a long shot but yeah enjoy
Sooo many Skylines :D
Great day everyone, thanks to all who came, Andrew for starting this, and Jayce for his organisational skills on the day, and keeping us in some sort of group through traffic :)
Great to see such a large turnout to a Canberra event, by far our biggest yet, great work guys and gals.
Ha!Now I know that last one worked(it did work,didn't it?):try some of these!My photoshop program doesn't seem to "like" certain pictures-it shuts itself down-so some of us,me included,aren't included...YET.Anyhow,let me know what you think!Jayce
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
