Hi Guys,
I need some idea's for my boot.
I currently only have a 4x150 pioneer amp in the boot, but will be adding another 2 ch amp and my pioneer 12" sub... i want to do a DIY boot install, with properly flush mounting stuff but i have no idea's... can people post some idea's for me?
Cheers y'all!!
Christian
https://www.sau.com.au/forums/topic/488-ideas-for-a-boot-install-for-nozilr/
Guest [ryan]
Idea's..
As in designs?
Shouldn't be too hard
I'll do you some designs and stuff if u want
Get me:
- The dimensions of your boot
- The dimensions of your sub box that the manufacturer reccomends
- the size of the amps
you got a cap? get a cap a half farad or something.
Prank,
I think I may have shown you the pics of my install before, but I have 2 x 12" and 2 amps in the boot of my R33. I used straps for the sub box so I can get to the spare if need be. Not flashy, but doesn't move and sounds just as good....
I can post the pics if you want..
Brett
Guest [ryan]
I should be able to design it so that the subwoofer uses a wide shallow box and it can sit up under the parcel shelf , but be removable if need be, and then make a false floor with the amps flush mounted or flush mount the amps on the side of the boot i am unsure where the r33 spare tyre is so we will work it out. it's not hard to do (flush mount) and carpet is cheap like $30 for a bag of it from Jaycar.
I was thinking about putting a 10inch or something next to the battery,
but after taking some measurements it looks like i'm gonna have to angle
it and stuff. I was planning to put my amp there also.. :cry: Just something
small and light and out of the way.
Prank,
You didn't specify if u still want boost space or it didn't matter.
EVLR33,
Pics would be sweet man, [email protected] .
Um, i wont mind if i lose my boot, but i'd prefer to have a little bit of space left.
I need to do something with my stereo soon... it sounds shite atm.. i just priced a nice 'wood deck that plays mp3's, $900.. has a changy colour screen too.
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
