  • Replies 60
>What will fit on a s2 r33?
>i may want some side skits, rear bar etc (except I want to keep my s2 front bar). Will those eyelids fit onto my s2?
>I'll only be interested in jan/feb next year after i graduate from uni.
>Mark
Re: fibreglass stuff
It all fits your car. E-Mail me at [email protected] when your interested.... Please bear in mind we are only getting them this cheap as part of a group buy and they normally cost a lot more.
I've got a series 2 R33 and pm Dr Drift.
The question I asked is up the top with the '>'s and his reply is sandwiched between this text and my question.
Looks like all the bits will fit on a s2. s1 and s2 are different so i'm not 100% convinced that it will fit on a s2. Maybe you can query him?
Mark
>Mark
Mark
I know for a fact that the eyelids for the series 1 wont fit the series 2.
Yeah, thats why I left Dr Drift a PM because I wanted to make sure they would fit. I'll direct him to this thread and maybe he can clear this up.
Still wanting a car for the prototype of the eyelid?
Mark
already talked to him!
he hasent got 1 for series 2!
can u take your car down to get the template done?
Where do I need to take the car and how long will it take?
Does it matter if I do it after the 26th (after my exams?)
Mark
Call fatz aka Pete on 0409226626
As he said he'll need the eyelids for an hour or two..... I'm sure you'll make many peopl happy if you do it :(
yep thats the same guy i was gonna get em off!
he will make your for free if u let him use your car to get the template
Ok, i'll organise to do it after the 26th.
Called Pete then, after the 26th is fine with him. I'll get the details off Pete when he gets back to me and let you know whats happening.
The eyelids can probably do different styles so maybe work out what style everyone likes and see if they can do it? - possibly will just be modified s1 eyelids... before I get the details I don't know what the deal is.
Mark
Mark
sweet, keep me informed as i wants the lids for sure.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
