Hey All! I have a bit of a problem
I bought a power FC for my auto 34 but recently found out it wont work!!!!! so now I need to find a good computer that will work- considering theres a few ppl on here with autos I was wondering if anyone knows of any???
AboBob if you see this have you looked at this for yours by any chance??
thanks people!!
https://www.sau.com.au/forums/topic/49298-r34gtt-auto-computer/
Wolf 3d causes shift problems. You can use an emanage. Check the What is the Greddy Emanage thread which is stickied in the Forced Induction section.
Also I started a thread called Info for GTT Tiptronic owners here http://www.skylinesaustralia.com/forums/sh...light=tiptronic
Mine is a one off at the moment but I will let everybody know when you can get them for yourselves.
If you want you can come over on the weekend some time and I'll take you for a spin so you know what a modified stock ECU is capable of.
Bit of a messy dyno run here but you get the picture http://www.skylinesaustralia.com/forums/sh...ead.php?t=49209
Yeah I spoke to PowerPlay and they mentioned the Greddy Emanage to me aswell- I think they can get them?? but they're also pretty expensive from what Ive heard.. Power play also said they have an ECU ROM they had made themselves for the autos but its $2500 for a 29kw increase and I dont know what happens if you get more mods for it later..
u pretty much can use any of the local computers as long as u retain the factoy computer to run the tipronic...what needs to be done is to piggy back the unit onto ur standard comp....emanage can do this but i heard there not that great....haltech,microtech,ems....will all work...i personally favour the haltech...cheers!
The Haltech one sounds like it could be good!!! any idea on when its released??
As far as the Apexi one goes I plugged it in and turned it on and checked the warning lights and they were ok- but I didnt try and drive it though cause I dont have a hand controller and I wasnt sure what sort of tune is on it... The main problem only happens apparently while its driving
I guess you could put a uni chip in if its available but you cant tune them as well as a full comp or piggy back
Did you try the Power FC, or did you just listen to the rumours?
I have a PFC in my series 1 R33, and it works well, yet I have heard others say they have had trouble.
The Power FC cannot control the tiptronic auto gearbox in the R34 GTT's hence why it can't be used. The only ECU that can is the Nissan OEM ECU
Not rumours... Fact
i think ur refering to the haltech interceptor comp...its targeted to compete with stuff like unichip and emanage ....'inside goss forot to tell u' its not available for skylines!!! only ford xr6 and wrx's.....it all comes down to budget!!!!!! put out a price ur willing to spend and get the best computer for it :) the top of the range haltech was put on a manual r34 ie. e11v2 the owner said it was better than standard if that is any indication...in terms of economy and power :headspin: :headspin:
theres a guy in the for sale section who can mod the stock ecu and remove boost and fuel cuts and take off other limits and optimize a/f ration for about $300 i tihnk it is. the thread is titled r32 / r33 ecu remap. he can do r34 as well, which should do the auto fine as its the original oem ecu
Can't you just run the PFC as a piggyback and get it to control everything else except the Auto??
Hope so, cause I was getting the AP-PFC with this in mind for my R32 GTS4 RB20 Auto.
It should be able to handle all the std sensors etc I would have thought.
The ECU I have at the moment was custom tuned by Martin Donnon & Simon at Morpowa after driving it to Adelaide. (170Kw) BUT I cant drive to Adelaide every time I change something :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
