I have just recently got myself a rechipped access (blitz) computer, anyone had any experiences with these access computers....mine a 34 auto and must say that its runnin a lot better then the stock ecu
doesnt anyone make a straight swap-over computer for these things!?!?!?!?!?
the main problem is that the Nissan ECU has a direct serial link with the trans computer. so unless the aftermarket manufacturer completely replicates the link, protocols etc it makes it very difficult. until we get a daughterboard working with the R34s (im working on R33 first) with a standard emulator and software you'll prob have to look at something which intercepts in the meantime
Yeah I spoke to PowerPlay and they mentioned the Greddy Emanage to me aswell- I think they can get them?? but they're also pretty expensive from what Ive heard.. Power play also said they have an ECU ROM they had made themselves for the autos but its $2500 for a 29kw increase and I dont know what happens if you get more mods for it later..
$2500 ??
cant you get a manual conversion done for little bit more than that ?
Coxy,
Believe me, e-manage would have to be your best bet at the moment. Ring up Peter at Advan Performance in Silverwater. He installed one for me including a Profec E-01 electronic boost controller. So far, so good. Check out Serious Performance 7 (white R34 with 220 kw). Now it's up to approx 270 kw
Coxy,
cool well if I keep the auto Ill go for the emanage- in the meantime im going to check out converting it to manual I think- I want a manual car again!! and plenty of clutch problems......hehe
Ill give Advan a call - thanks dude!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
