Just wondering if anyone knows or has any ideas about this loud whistling noise that goes on for 2 secs straight after my car has turned off.... i try hearing where it comes from and its definately near the turbo/manifold/compressor area....was thinking it might be the bearings....but my t28 turbo runs perfectly and boosts up properly and even on high boost....
I had a really loud whistling noise once the car warmed up once.
Popped the bonnet couldn't see anything.
It was a pin hole in the top radiator hose.
What I found interesting is at first there was no signs of steam.
Just a damn loud whistling noise.
mine does this too.. Sounds liek the car is sucking back or something..
Not sure but I'll monitor this thread and let you know if I find the problem.
Its just as you shut the motor off right? ass soon as it stops you get a suck back kind of noise?
It sounds just like a kookaburra. no joke, i know it sounds weird and funny but it sounds just like it and goes for like 2-3 seconds...even whe im just idling at the lights waiting...it sometimes goes off again....its definately near the turbo area....
It sounds just like a kookaburra. no joke, i know it sounds weird and funny....
Are you sure you didn't suck a kookaburra into your engine while you had the air filter off? That would cause a kookaburra noise.
I think it happens a lot with the bonnet scoop on the WRX sti as well, birds and small children often get sucked into the engine
Check your belts, eg, alternator, power steering, A/C if all are ok maybe your timing belt pulley is seising up, it tends to try and jump off the pulleys on down revs,
How many km on the clock? if 100,000km it will be due for timing belt change.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
