I Just wanted to get other peoples view on this
I'm currently looking to buy a R33 GTST -1997 - Manual - 12 months rego Mspec
full stock , mint condition for $24,000.00 is this a fair price?
Will be the 1st driver in australia just imported.
Is there any point in doing a rev check when its only been in australia for 1 week.
will be the 1st australian driver?
If the car has only just been imported, it has obviously never been registered in Australia before so it will not have had any finance on it.
REV's checks for encumberance on a vehicle, ie money owing, so this wont be nessesary on a freshly imported car
I bught mine the same way you did.
Someone imported it and i bought, so second owner in Aus but 1st registered on road owner.
The don't bother with REVS comments.....just do it man!
I did even though it was just in. It doesn't hurt and takes you a whole 5 mins of your life!
...and its free.
get the vin nuimber checked... nissan at hornsby will look it up for you... this will show if it is the car that left the factory with the vin that is on it now, colour etc..
also get someone who knows these cars to check it out for you, lots of things can be wrong with them!
iissavi: The guy you need to speak to whos clued up on imports at Hornsby nissan is away.
Also an NRMA inspection is a waste of your money, they will happily tell you that your wiper blades are ok and your tyres are fine but they arent trained in performance import vehicles so you are best to either arrange to get the car inspected at a performance shop or get someone you trust and who really knows his stuff to go over the car with a fine tooth comb. Either way make sure you do a compression test.
Where is the place you are buying the car from?
iissavi: Tell the dealer/seller that a condition of your purchase is that they allow the car to be taken to a reputable import performance workshop for a thorough checkover prior to laying down any funds.
I sold my GTS-T a few years ago and Jim at CRD in Silverwater inspected my car for the new buyer and I was incredibly impressed with the level of detail they went to.
They checked the engine, body, every switch inside the car, radio, road test, braking, suspension etc etc and dynoed the car to ensure everything was in good working order.
Expect to pay around $200 for a full inspection, and believe me, its money well spent.
I normally speak to John in parts at Nissan
You may be able to try the parts division at Crows Nest Nissan as well
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
