When looking around at R32's I almost bought an Auto R32.
It wasn't too bad off the line, it did feel a little dougy but that is the nature of the RB20DET's. Once up on boost it did pull hard and hit second gear nice and solid.
  • Replies 54
Have you driven an auto Skyline Dave?
They are no where near as bad as you are making out...
Plenty of them are pulling good times too...
yar, i dont doubt that theres not much performance difference
i just like slaming my line through the gears, up and down
everyone is quoting these times given by nissan and other performance magazines. without giving them a thought...
well think about this:
when nissan (or a review magazine) does its testing, they have professional drivers that know exactly what rpm to change gears at, and exactly how to take the car off at its optimum level. how many times have manual drivers got that little bit too much wheelspin? or a lot too much wheelspin? or bogged it down with no wheelspin? or chenged gears too late? or too early?
take a stock R33GTSt and i mean STOCK and you won't get anywhere near the 6.1 seconds 0-100 quoted by nissan.
an auto is much easier to replicate the times as many variables do not exist. its easier to get a good takeoff with a bit of stall, and the gear change points are already worked out. at the end of the day a manual might pull 10kW more on the dyno, but a sh1t driver can ruin that when you are at the quarter...
Waz.
or buy a 4wd hatch... :D
don't forget autos run a different diff ratio and gearing ratio better for acceleration - i think that makes up for a lot of the shortcomings of an auto, and why it is that way.
Yeh basically what everyone has said is the same;
Autos only weakness on straight line speed is the take off.
Some of those autospeed writeups are full of easy to make errors.
But yeh, as waz said, another advantage is consistancy.
Automatic these days arent what they used to be :D
I doubt an Auto R32 with 16psi of boost, exhaust and fmic will run a 5.2-5.6 sec 0-100. :rofl:
Saying that I've thought about the idea of an Auto behind the RB30DET.
The increase in fuel consumption is what gets me worried.
What sort of fuel consumption are you blokes getting in your Auto's?
When I had a VL I picked up around 80km's per tank by converting to manual.
in regards to your auto VL and your fuel consumption, i agree big time! my VL had zorst, cooler, pod, boost, and a microtech ecu. auto had a stall converter and shift kit - and the thing would struggle to get 220 k's out of a tank - driving like a grandma! wtf? oh yeah, and it was tuned good aswell.
i know it's a big difference, but my R34 gets close to 400 k's out of a tank nailing the arse off it. pod and zorst are it's only mods.
It depends on the set up, I have seen 2 X auto 2wd Skylines run 9's and 1 X auto 2wd Skyline run an 8, but I have never seen a manual 2wd Skyline get under a 10. If I was building a 2wd Skyline drag car I would build an auto every single time. But that doesn't interest me, so it's manuals for circuit racing everytime. For towing or driving in traffic the Stagea auto is hard to beat.
As usual, it's horses for courses :)
rs73 it may have been aftermarket auto, or it may have been rebuilt, but show me a manual running those sort of speeds that still uses a factory box (I bet they are also aftermarket or modified gear sets). I think its a given that at those extremes you will have to do serious work to the whole driveline.
It may have been aftermarket, or it may have been rebuilt, but show me a manual running those sort of speeds that still uses a factory box. I think its a given that at those extremes you will have to do serious work to the whole driveline.
Change the auto box, sure. But 2 of 3 those cars run totally standard drivetrains from the tailshaft back. That's very, very rare in a manual, the shock from the mega clutch that you have to run, coupled with the sticky track and tyres, rips the shoot out of driveshafts, uni's etc. Never seen a diff break though, damn tough those things, not called the "Japanese 9 inch" for nothing. :) .
Sydneykid, I agree with you (and have edited my response to make it more clear) the autos are often under-rated and are the ideal thing for drags and street work. (admittedly not for track work yet, but if they release a 6 speed tiptronic auto, it may be the ideal thing for track work aswell)
PS are you still heading to Adelaide some time soon? the offer to try the auto with the PFC still stands. (And I'd love to get a look at your Stagea, its probably our next car to replace the wifes ford wagon)
Adelaide, the guys were there a couple of weeks ago, but I didn't go, too much work. I think we are there about the same time next year, the calendar isn't finalised yet though. Maybe we go to Mallala twice next year as the Improved Production Nationals are on there.
Don't underestimate the autos on the track, the Tilley brothers used to run a couple of Chrysler products in Appendix J with the push button 3 speed auto. I can't say as I ever saw them loose a drag to the first corner. High rpm stall converters and tightly locked autos with push button sellection, make sure the power band of the engine suites the gearing. (Just in case Steve-SST is reading this), their engines made plenty of power, they have a Dyno Dynamics dyno in house. It doesn't run Shoot Out mode, but it never stopped their cars from winning races.
My R33 is auto had this done
3.5"turbo back exhaust with custom super flow dump and high flow cat
750hp fuel pump 550cc injectors
pod filter induction with cold air mod with r34 stock cooler
turbo smart dual stage bc running 7 and 12 psi ,SAFC
springs and shocks
off the line no wheelspin just flies from the get go, chirps 2nd most of the time
have found that that is the down fall with mates manual 33's while they are still spinning or chirpin through 3rd i am waiting with the drinks.
havnt done quater since put mods on but mates run mid and high 13's and i beat em so i should be doin low 13's or maybe better haha
GO THE AUTO's
Not that manuals are bad though
GO MANUAL's also
I have put new fluid in my auto box and can report sharper shifting although it could be better. I don't think I got all the fluid out of the torque converter so I have ended up with a mix of old and new fluid.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
