I have just recieved my '93 R33 (supposedly a Type-M) but it does not have the more aggressive looking front spoiler that I see on most skylines getting around.
Instead it has the fairly sedate looking front spoiler.
My question is, what defines a Type-M? I dont believe this car is based on the front spoiler but am I wrong?
Does the more aggressive style spoiler fit straight on? I picked one up the other day (thanks Yazid) and havent yet tried to see if it will actually fit (I am concerned about the mounting points at the bottom of the skirt as the current spoiler not lining up.
I am also still trying to find out if the paint on the rest of the car can be sorted - there appears to be some crazing of the paint on the bonnect and roof that I dont think it going to polish out :D
https://www.sau.com.au/forums/topic/5000-what-defines-a-type-m/
M-spec R33 GTS-t...this is a good question...
As far as I know, the front bumper is called the M-Spec front bar, so the bumper is part of the package. I "think" M-Spec also got ABS Brakes (maybe the rumour was about this and not bigger brakes)
One thing I'd like to know is if M-Spec class r33's where treated to side skirts ?
Yups its rite,
Type M/M Spec R32 had a GTR bonnet,
As for the "Type M/M Spec" in R33, it means all turbos, so GTS't are all "Type M/M Spec" regardless of the body work. As like i said b4 Type M/M Spec means turbo.
Mine has ABS dual airbags and is a series 1. i don't have side skirts or a "Type M/M Spec" front bar.
So yeh, essentially "Type M/M Spec" means turbo R33.
:D
I think it basically comes down to the fact that the R33 had a big options list when they were new - thats why you see skylines fitted with all sorts of options
For instance mine is almost identical to the "Type M" shown on the Skylines downunder link with side skirts, front bar, and red S badge, and an extra rear spoiler lip underneath the normal series 1 spoiler.
I seriously doubt that there is an upper specced R33 Type M like the R32 apart from the normal turbo model
Use the "search" option for this kind of info'.
I've posted info on both SDU & here about the "Type M" designation a fair few times.
100% CONFIRMED WITHOUT DOUBT - THE R33 "TYPE M" DESIGNATION MEANS ITS THE TURBO MODEL!!!! (not including the GT-R).
There is no such thing as an "M Spec" R33 GTS25t/GTS etc... M Spec has come about from people confusing Type M for M spec.
An R33 GTS25t is a Type M fullstop!
There's no such thing as a non Type M R33 GTS25t!
It may have ALL the options fitted (bodykit etc..), or it could have NONE (standard front spoiler etc..). It depends on what the original, or subsiquent, owners wanted.
I'm not plucking this info out of my arse, it's straight out of the original Nissan Japan sales books sitting in my bookshelf @ home :)
  • 7 months later...
Originally posted by surreal
As for the question of a 'less aggressive' front bar, you are prolly looking at a series one bar.  The series two front bar was much less docile in comparsion - it had more square/aggressive little air dam things and was less 'rounded' generally.
There are 2 types of series 1 bar, the bigger one is often referred to as the "Type M" bar, or merely the "front spoiler" bar. It was a factory option.
Type M just means "GTS-t" for the R33. It is confusing because it didn't mean the same thing for the R32, and then there were spanners thrown into the works with the likes of the Nismo Type M linked above.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
