Mods...both
Performance...GT-t mainly cause engine will be newer lol
Handelling...not sure
General performance...not much in it lol stock wise
Im selling up at the end of year to buy a 34, 33's are nice but they are getting old man. and they are as common as dog shit now
34 stockies go for low 30's...
33's range from shit ones...mid 10's to nice stockies high 10's and reasonably modded low 20's depending on whats on it
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-997998
Guest RedLineGTR
From being in both type of cars. Depends how much money you want to spend. In those budgets I would only consider a "late" series 2 in the r33 gtst range at a minimum if you wanted a r33 otherwise I would say get a r34 gtt all the features, added options, cosmetic looks, performance etc all add up to the price of the R34 gtt and is worth every penny.
My 2 cents. Rob
BTW Your the one who will be sitting in the car most of the time (unless someone else uses it) try a seat in each car and which one your are more comfortable with.
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998010
I looked at both when buying my skyline and the 34 is definitely worth the extra price.
Whilst fundamentally the same, the extra refinement and newer age are a big plus. And also as previously mentioned 33s are getting very common, whilst there are a few 34s out there, nowhere near as many.
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998076
the neo motor has solid lifters and it's factory power rating is higher than the 33.
the only bad thing is 2nd hand parts is hard to come by with things such as suspension parts, body parts, interior dress up stuff etc...
but i thought it wasn't as easy to tune and doesn't take mods as well
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998124
I think I will end up saving for a R34, the do produce a nice torque band stock and are modify-able.. Just a little more pricey at the moment, but I'm sure they'll go down as time goes on, I'd love to do one like the one in your avatar torreto, or perhaps a black one..
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998372
33 -> cheap, everywhere
34 -> newer, better and more torque engine, cool styling (at least in my opinion anyway), not as common as 33s, nice dash, more boot space and also more backseat room :D The only downside is the price.
Ultimately the choice is yours, I have test driven a few 33s (modified and unmodified) and a few 34s. At the end the 34 is what I did purchased, I would go so far as to say that the 34s can be used for a family car quite nicely. :(
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-999076
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
