the contact details is on the last page of the import approval doc u fill out.
They actually say on the answering machine thingo when you call that 'unnecessary enquirys may delay issuing your import approval' .
Not sure what to take of that, what do they do when you call them? put your approval on the bottom of the pile???
  • Replies 250
yeah just received my IA as well on monday.. faxed it thru on the afternoon of the 31st of September. so taking around 3 weeks to get here. been waiting to send that since Feb this year.. long wait coming to a end
I got my approval, contacted J-spec and was told basically. "Fux knows when it will get on a boat. They're all full." :hellpisd:
Oh joy, gonna be like last year when I finally picked up my 33 on Xmas eve, 17 weeks after I bought it in Japan. :boohoo:
ok so is there only one shipping company that comes to aus?
I just faxed mine in this morning (twice to make sure) and at lunch am going down to get an express post bag so they have the originals of my doco
man I was hoping to drive the f#$^*( thing before xmas. this was my present to myself :D
mark
mark, i'm in the same boat.
Give dotars a call (the number is on your import approval paperwork) and make sure they have received it, ask them how long it should take.
Tell your supplier in japan to find out when the next ship leaves that has space on it. There is a ship leaving early December, im trying to get my car booked on that, even though i don't have the approval yet.
Faxing is definately quicker at the moment.
I sent my application express post on 29/9 and received it today 1/11
As for shipping apparently up to 85% of car carrying ships is allocated to new cars atm
and everyones trying to get a space.
You do have the option of putting a car in a container as they leave weekly instead of at
the end of the month,but this will add at least a k to the cost.
Btw next ship to dock in freo is the Arcadia Hwy
13th NOV
well i just got an email from Geoff and he said that only 2 out of the 5 cars he had booked on the ship made it onboard.
the 3 were bumped off. he'll let us know who made it and who didnt. knowing my luck, mine will be sitting on the docks. :(
he also said that the next boat will be 4 weeks away.
steve
hope thats not the case steve
I have emailed craig this morning, I got my IA faxed through to dotars yesterday morning at 7am
then sent the originals xpress post for arrival today
I don't know how long the form takes, but I assume if they could get it on the next boat (like they were trying I beleive) then the form would be back to me before the car arrives
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
