been thinkin about getting a screamer pipe ..for the hell of it ..and put it on while i get the intercooler fitted ...although what daunts me is what will be the results ......the cars fairly loud now ..does get a bit of attention as it is .... but i just wanna replace the standard dump pipe to some more "beefer"
i've neva heard a screamer pipe on a car b4 ... well maybe ..i'm not sure what i'm listenin for
are there any down falls to it .....any like things to be aware of ..ie the screamer pipe making any flames or somthing?
but on the same token ..do u gain about the same power gains to a split setup? just not venting it to atmosphere ..
anyone have either one ... anycar ..doesnt matter . just wanna see what ppl have found with em ...... and if one or the other is worth buying over the other .....
thanks for your time.
Matt
https://www.sau.com.au/forums/topic/51030-screamer-pipe-vs-split-dump-pipe/
i heard a screamer on a mates 180sx SR20 and it sounds rather ugly, leaks at idle so sounds abit wierd and once getting up it, it is amazing the noise that is produced, when racing him i cant even hear my own car. Seems to produce abit more top end, but i cant see there being any advantages over a split dump setup
i've got one on mine, its flaged so i can plumb it in if i want to.
If you want, ill take ya for a quick burn in my car so you can hear it???
Mines pretty loud as its coming of a big Ext Gate and has a pretty big pipe to boot.
I must admit, they are farking angry as shit when it comes on boost.
Real feral growl.
But after getting it plumbed back in today, i'd almost be tempted to leave it.
Screamer is good... but once you make it quiet, and with a big turbz, all you can hear is this crazy areoplane kinda noise when the turb is on song. And the car truely sounds faster i reckon
But depends on my mood i guess.
while i think of it, evertime i give it a hard drive i get some funny smells :)
just as the red-hot air is hitting the underside.
Not damage being done though from my checking, but the smell is going slowly so it must be burning some shit off
yea ash would be sweet to actually hear one "first ear" ..... as i'm still weighting up my options for turbo ..either t04e wastegated or internal... i really just dont know ..i know there loud .. as everyone has said ..... but i'm used to hearing 370ci plus sprintcars at 15feet away rifle around a 1/4 mile dirt track .. more noise doesnt hurt .. much ..unless u over 128db ..(aka threshold of pain)
only concern is getting reamed by the jacks on a nite out somewhere minding my own burnouts .. i mean business.... :) ..but it happens as they say..
Matt
screamer means that you cant hit boost around other cars/people without everyone knowing for about a 2km radius. it is a bit of fun, but i was always planning on plumbing mine back to the exhaust.
oh and i dont think it would be that far away from the pain threshold :)
  • 1 month later...
is it possible to get a screamer on a wrx?? i have myself one on my skyline but my brother wants one on his wrx.. just seeking some help if you guys have seen a screamer on a wrx b4? one more questions.. you guys know what is required to be able to get a screamer ?? you guys know any good cheap places in melb to get a screamer pipe done??
thanks heaps!!
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
