well as some of you may have read i am in the process of trying to decide whether or not to open a car and parts store for all imported cars, somewhere on the outterskirts of melboune (at the moment the Coburg area is where i am leaning towards) So now is the time i need your help as you are the customers and this store is to benifit you as much as it does me so,
WHAT DO YOU WANT?
any thing from spare cigrett plugs to full motors and gear boxes, bodykits and even turbo kits new and 2nd hand. please any information would be great as i said previously this store will be open for YOU and YOU know what YOU want.
Greatly appriciated Lee.
https://www.sau.com.au/forums/topic/51086-the-time-is-near/
Are you going to have a workshop as well, or strictly selling parts? Because you will need somewhere to store all the parts. Could be a good idea to lease some of the warehouse space to a mechanic as a shop OR rent the area out to ppl at say an hourly rate. I dont know how you would go with Worksafe and duty of care etc etc if you are leasing workshop space to the public, but i for one now living in the city with nowhere to work on my car would pay soem coin to have access to somewhere i can work on my car.
Just an idea...cash flow is important when in business...good luck!
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1012733
you will need to supply the usual stuff like, exhaust, ECU's, injectors, fuel pumps, suspension, rims, turbo's, manifolds, turbo kits, rims, gear box's motor's.
Also search other companies that are already running for idea's
www.japanesemotorsport.com.au
www.option1garage.com.au
www.justjap.com
www.upimports.com.au
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1012737
if u can get me some gtr front and rear 1/4 panels at a good price (already been quoted) id b keen to shop there often n would prob send business there
also would need to have good c/s but im sure u would keep that as high as possible anyway
roy i like ya idea of hiring out space to work on cars
btw a hoist is only worth 5k... small investment that will go far
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1013001
                                              WHAT DO YOU WANT?
I was thinking about doing a similiar thing also with a mate who has plenty of $$ to invest in such a thing.
The thing is that there are so many shops around vic and aus and so many online stores (ie no overheads) that the market is very compedetive at the moment.
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1013222
www.justjap.com
:werd:
Also, I would be keen on GTR bonnets for R32s' as well as sideskirts and rear pods, oh and don't forget the usual supply of second hand mags like TE37s and other popular jap mags!!
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1013234
i'd say one thing that it not stocked a lot is accessories.
you can gt some at places like autobarn but lets face it they are a rip off!
things like:
gear knobs, stickers, keyrings, keys, badges, etc. etc.
but also have the usual bodykits and mechanical parts
it would be perfect if it were the 'ultimate' store where you can go and buy your parts, then your rice and you're done!
Warren.
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1013237
DVD's maybe and even a handfull of basic servicing products like sparkies and oil(2 brands max say like motul and fushc) for the same price or better than autobahn.
oh and a hidden gambling den in the back with flipping pool tabels that turn into roulet tables:D:D
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1013449
:D
https://www.sau.com.au/forums/topic/51086-the-time-is-near/#findComment-1013606
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
