  • Replies 334
I got an email back from Jspec about customs and stuff this morning and it sounds like its all organised for me
"Once the car arraives you will be sent an invoice from the customs clearance
agents - this will include import duty, GST, port charges, etc... payment
for this will need to be made into their local bank account before the car
is released from the ports.
You have to use a customs agent, it is not possible to lodge a customs
clearance without a licenced agent"
its finally happening! my car will arrive out the front of my house tomorrow!! its been a long wait (sook) the car arrived in brisbane on the 30th of august and one month later it will be in my hot little hands (not to mention wet and sticky :boinkcar: ) so happy, hope registration and all goes well
:jump:
You have to use a customs agent, it is not possible to lodge a customs clearance without a licenced agent"
Some of the guys (razorsharp, for instance) that have done their own customs stuff can comment, but AFAIK there is nothing to stop you (except time and running around) doing your own customs paperwork and organisation.
LW.
Got the 'Arrival Notice' from the shipping company this morning. ETA is 4/10 (Monday). Ship berths at Webb Dock which is only about 1km from where I work so might go down and have a look (I know I won't be able to get to the car, but might catch a glimpse....)
Still no B/L and I've noticed they've spelt my street address wrong on the arrival notice (one letter)....hope that doesn't cause any problems.
FYI, my B/L was not sent directly to me, it was sent to my customs agent - perhaps your B/L will to?
According to Geoff (prestige) it should come to him and then he'll send us (myself and the customs agent) an e-mail copy which should be sufficient to clear the car. Anyway, Geoff keeps saying 'don't worry it'll be here' (guess he must get hundreds of e-mails like that, LOL), but I'd just feel better knowing this last piece of the puzzle was in place.
Yeah, im actually quite pissed off with the hole fiasco right now. I have been waiting for my B/L since September 11 and it finally was sent on Monday (after the ship had docked how f'ing useful) and it has arrived in Sydney according to the EMS tracking info but CGL have checked their PO box and nothing.
So now because of this i am going to be liable for storage fees over the long weekend, another extra day for steam cleaning. I should send the moron who didnt send the B/L when it arrived the bill for the storage.
Importing is about the most frustrating and painful experience you can ever go through.
Anyone else who has got approval in the last few weeks waiting for a shipping date? Kinda sucks too now finally have approval but no sign of the car getting on a ship yet ;)
Well I'm now glad Geoff took the risk (on my behalf !) and got my car on a boat before I had approval...but it did cause a level of stress....
Ship docks 3:30am Monday morning, but still no B/L and that's a worry.
Geoff booked my car on a ship prior to approval, but apparently there are delays in Japan at the moment ;)
LW.
Everything is done for mine now - went to see it at the docks today and took this photo from a vantage point near the office. Cant get closer because the security wouldnt allow me but at least i can see my car is there:
(its the black GTR behind the white skyline ;) )
Mate i got to drive it today for about 500 meters (on a private road etc). I have been without boost far too long. Im in love with it.
I imagine you are still smiling :)
500 meters? so only about an 11 second drive then... :)
Richard
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
