Guys, a few questions for the learned:
1/. Turbo slowly gets noisier and noisier, then all of a sudden HEAPS of oil smoke out exhaust......stuffed turbo oil seals, right?
2/. A good (and cheap) water cooled turbo upgrade for an L20ET, I'd get a ??? of a ??? (more interested in reliability than performance upgrade)
3/. How hard is it to get the turbo off an L20ET?
4/. L20ET + L28D crank and ??? rods/(standard pistons?) = L??ET (how many cc's and how hard to do)
5/. Does anyone have a central locking motor from an R30? - Long story, you don't won't to know.
Not urgent, car off road for 5 months, but any responses would be appreciated.
machg
https://www.sau.com.au/forums/topic/51351-hr-30-problems/
ok for starters you have a dead turbo there, a replacement turbo would be something like a ball bearing rb20, your turbo on the l20et should be oil feed as theres a oil line running from the oil sump to the turbo, i had a bitch of a time trying to get the turbo and manifold off my old l20, ended up just getting it all taken away?? i think each door has its own motor in the r30, a wrecker with a MR or HR should be able to get a motor for you, i've got a centre control unit waiting to get the motors for the hr30...
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1017457
1. More than oil seal me thinks!
2. I'm sure the L20's had T3's stock,so I'd go a T3 style turbo....maybe an RB25 BB (R33 Skyline) ,or an older stlye water cooler T3...
3. How handy are you with the spanners? It's not real hard...
4.???? Ghostrider would be the man for that one
5. As RSX said....or buy a Jaycar central locking kit for $40 and use a solinoid from that.
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1017655
RB20DET turbo bolts straight up. Need to manufacture the water lines though.
Actually, I've got one here, off a red-top RB20DET, that you can have for about $50. Needs a wastegate actuator, though.
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1017819
Yeah, originally after discussing the problem (driver's door lock stuffed) with the guys at Jaycar, they sold me a "remote locking/alarm" kit, which (unfortunately) didn't come with any solenoids, I guess Jaycar might sell me a spare solenoid (considering the kit they sold me doesn't work to my satisfaction). Geez I reckon changing turbos on the last model 300ZX would have to be easier than changing the turbo on an L20ET; what an absolute BITCH of a set-up.
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1022286
L20ET update: Its Not Impossible! Managed to finally get turbo off engine. For those interested; this is how I did it. 1/. remove all attachments to intake manifold that prevent access to retaining bolts. 2/. Remove all shit you can from around exhaust manifold and turbo and undo exhaust system at end of dump pipe. 3/. Undo and remove all manifold retaining bolts. 4/. Remove intake manifold, remove exhaust manifold. Getting turbo off exhaust manifold is a piece of piss once removed from engine bay. Four 17mm retaining nuts with captive washers (bend away with small screwdriver)
Sounds easy? Its NOT! To get the bolts holding manifolds on underneath them you need small, a good quality 12mm socket, long extension (at least 15cm long), universal joint and ratchet. (Sydechrome - thanks Dad!) and smallish hands (I could JUST squeeze one hand in to feel location of bolt heads).
Door locking motor: Jaycar does one for $10, will fit today.
Thanks for feedback guys, I hope someone finds this interesting/useful.
machg
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1028338
if you have central locking theres little motors that pull down the locks?? when you push down the main door lock....
Push down the main door lock???????
What's this that you do???? My central locking works when I push the button of the remote!
Anyways, doesn't the stock MR30 Ti central locking work off the key?????
4/. That's right, I probly be the man for this. Don't waste your time with the L20A engine block, it might be the same physical size as any other L series 6 cylinder, but you cant put a 10.0 mm over bore down it, the cylinders get a bit airy!
If your going to do the stroker deal, you need a bigger block and not ZED blocks as their sumps and oil pick ups are all in the wrong place for R30's, and the LD28 crank is only comp[atible with another L28 block without a fair amount of machining.
Do lots of homework on the subject before you embark on it, as it is super expensive and more so if you **** it up. It is not the sort of engine build you can do and cut corners, it's either all or nothing and then it has to be THE VERY BEST of ALL, not what you can afford.
I have got all the bits, but i'm not going ahead with the build until another day, the easiest way is build a stock L24E into a turbo using maybe the L26 crank and find some pistons, the L20ET manifolds all bolt on.
A TURBO! An T03 off an FJ20DET is identical in every way to the L20ET turbo with one very important change, the turbine housing is nearly twice the size, from .46 to .87 A/R which should make it spool up faster and produce more power. The FJ T03 mounts to the stock manifold, just like the old one (L20ET)
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1039523
Thanks Ghostrider, sounds like the easiest power upgrade is to wind up the boost a little! Going with that turbo off the RB20DET (cheers BlindElk) be back on the road early 2005.
machg
Unless your going all the way to 3090cc, the stroker isn't really the go and to have a strong 3090, the F54 280ZX Turbo block should be used, in conjuction with a P90 head.
At the end of the day, some extra boost is the answer in a lot of cases.
Dennis
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1039590
Hey there Ghostrider, how goes the Newman & RMR?
The L24 will rev harder, but the L28 will pull stronger. My L28ET 240Z will make 15psi at 2000rpm. The stock NA compression is influencing that but it pulls like a truck.
It is not too hard to produce 400HP+ out of a mildly prepped L6. My under-construction TT F54/P90 engine is aiming for 450HP, but SKY-084 here in SA has over 180kW at the wheels with an LPG-only L'27' setup (including locked dizzy).
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1042312
  • 4 weeks later...
i've also been told that the turbo off a VG30 (single) will bolt up as well and being a newer model should work as good if not better than the FJ, but remember it's off a 3lt, maybe use the L24 block(for under 2500cc comp events) and might work ok! also what intercooler should be used in a r30? not much room and not wanting to cut up front bar(orig HR30,diffrnt to local)
put up extra photos of enginebay pls look!
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1072858
with the iron mask front, ive got the hybrid 600mm x300mm x70mm fitted low...
https://www.sau.com.au/forums/topic/51351-hr-30-problems/#findComment-1076457
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
