  • Replies 49
Geez - I think I might like this turbo :D
Boost starts at 2.2K (that's when it goes from vaccuum to 0 PSI)
At 3K I have 5 PSI
At 3.5K I have 15 PSI
At 4K I have 19 PSI (low boost, 25 PSI high boost)
Thats with me driving in 4th, leaving Peak Hold on the Boost guage, driving up to the rev limit specified then backing of - Then reading what Peak Hold says.
Compare this to the 3040
Boost starts at 3000 (ie 0 PSI)
At 3500 it has 5 PSI
At 4000 it has 8 PSI
At 4500 it has 20 PSI
At 5000 it had 23 PSI
So you can see I have much more respose. The car feels much more responsive and hence quicker on the street.
As you can see the 3040 hit real hard
The 2835 is much smoother - much nicer for street driving.
Now - to put it on the Dyno and see that the power differnece is :(
Cheers,
Mate - it's on my list of things to do ;) Sorry , been super hectic bro :)
Turbo is on, but should still be able to able to get you what you want.
Or if you wanna check it out for yourself , get in touch with me and we can arrange something ;)
Cheers,
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
