Ghostrider-do you know the specs of an HR31 R200 LSD? My diff has not been tightened,that I know of,and it will rotate both wheels,under any circumstances from a standing start,or low speeds....
Open wheeling round medium speed corners,or when the rear is under a lot of body roll,is a different matter though......... :D
It's about the same I believe. As you say you have mixed results with yours which is the problem, with such low preload, the harder you make it work the easier it will release.
  • Replies 46
Near enough!
Matt,
From my research, Cusco was the prolific a/mkt diff centre supplier of our cars era, Nismo got involved more into the HR31 era, but unless you had either of these, you don't have much better than an open diff as it sits standard.
It was more a selling pitch as I said before.
Look at today, all the new cars have viscous LSD's, but the serious guys are still fitting mechanical LSD's. Bet you don't find many viscous diffs in the WRC, but all to most of the cars sold to the public had them stock.
You will have to find a good motorsport guy/mechanic, find a Datsun Rally workshop up there, someone that's been playing for years with 1600's and the like, they will have all the guts on them.
Good luck.
I have 3.9 & 4.1 and looking for a 4.4 R200 for my arsenal, as the so called experts say 4.4 is the right diff for Wakefield Park
i know the r180 is not as large but if you get the front diff(r180) from a nissan 720 4WD the ratio is 4.89.....i used this in my datto 1600 for many years and it is an extremly tuff center...the crown wheel is a heavy duty one as it is for off road and IIRC the planetary shafts are bigger too...
as you know, the r180 also came with a cv joint driveshaft configuration so it would probably be worth the effort just to see if the ratio is what u are after....
btw the 1600 still had a top end of just over 200km/h so its not tooo low....and that was a 2.2 litre l20b stroker(not the highest reving engine)
Hmmm,fair enough.I thought the '31s may have had a bit more preload factory,cause as I said,low speeds or in a straight line,it's sweet.....with my RB20 in front of it anyway. I'm not planning much hard cornering/circuit use,so I'll leave mine alone till it starts complaining :D
I would not be in any great hurry to put a 4.375 ratio diff in a DR30 (actually yours is the RB20 HR30) . I tried that with my FJT Bluebird (4.375 H190 LSD) and found minimal gain and lots of revs for no good reason on the highway . I always found myself trying to change from 5th to the non existant 6th . The lowest I would go is 4.1 and often wish my RSX had a 3.7 . The RB26/31 will prefer it .
 Cheers  A .
I'm not 100% sure who you're replying to there (if indeed it is a specific reply :P ), but the HR30 is (originally) an L20A not an RB20 and the DR30 with a 3.90:1 is not 100% happy in 4th@60km/h. The option 4.11:1 is certainly a more suited ratio for around-towning.
I have no concern for highway rpm's in my DR30 - that's what the Stagea is for, and I only have 3.90 & 4.375 LSD's so the 4.375 is going in. I'll certainly provide feedback on the success of the conversion in regards to city driving, power delivery & economy when it's done.
Ghostrider, I might be able to find you a 4.375 R200 LSD - I'll get back to you.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
