  • Replies 189
what gross photos. thats me. *note to self - go to the gym*
God, you are kidding right? you were one of the nicest chicks there. :aroused:
sorry about the bad pictures, my video camera focused on the fence and not you :D
Show was ok. I did not go to the one earlier this year. It was pretty good I thought, But I had to hold my tongut with a few cars....there was an orange R33 GTS-t wth fluro yellow wheels and Graphics like the supra off FNF. Man, Where where his taste buds?
Leewahs car was a shame but Ross's RH9 R32 GTR Rocked!!!
Went both days though it was awesome. Earlier one in the year was probably a little better...
Chicks were wicked as you would expect and cars were insane...
Was good to see the R32 Pump out a HUGE 530kwand about 717BHP i think it was...
A Massive Shame to see that Sweet looking Purple R33 GTR Blow on the DYNO think scared the f**k out of everyone.....
Overall good show looking forward to putting my car in next year......
AutoSalon keeps getting worse and worse (promo girls aside lol)... too much ICE and airbrushing... and a lot of the cars were from the first autosalon this year... not too many real performance street machines... i only stayed for 2 hours... i should have gone to phillip island both days...
I agree....Airbrushing all over a car is crap. And really who cares about 4 tonnes worth of stereo?
But the trouble is, my car has none of that and it does not really stand out in that type of crowd. Most of the cars there had bonnets closed. I left mine open all weekend because it actually has more then a pod and some polishing.
yeah i saw your car... very nice... it's a shame all the good cars were stuffed in the back corner... :D
$22 to see a bunch of rice sh|t boxes (bar SAU's skylines) and girls who like the idea of a bunch of dirty guys staring at thier T&A.....Glad I went to Philip Island :D
Really need to get Autosalon back on track. Get some REAL machines on the floor not these 100K cars that can't make over 100kw on a dyno. Still, it's good for a perve.
Maybe it's just me?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
