Hey Sk, is there going to be much difference if i use an 85mm throttle body? Or am i actualy better off trying bigger like 100mm?? Im not up with this airflow stuff so please inform me? I wont be racing around a circuit, it will be dily driven on street with occasional willowbank day for drags and drift. no circuit racing. does this make the single tb choice alittle better?
Steve, I have "tried it" both with a standard RB25 throttle body and a Foulcan throttle body.  I could fee lthe slowness instantly on the road, and on the track it was disasterous.  With the dog box we have ~50 milliseconds for a downshift and you MUST match the engine rpm with the gearbox rpm.  Otherwise you end up with twisted splines on the input shaft from the triple plate clutch and missing teeth on the gears, particularly 2nd.
It is quite simple to understand why this is the case.  With the multiple throttles there is very little air between the butterflies and the inlet valves.  So when you close the throttle the airflow to the engine stops instantly, therefore so does its power production.  Compare that to a single throttle body with a plenum in between the butterfly and the valves.  The usual rule of thumb is at least double the engine capacity in the plenum, so on a 3.1 litre that's 6.2 litres.  Plus that 6.2 litres is under boost just before you close the throttle, so at 1.5 bar it really has 9.3 litres of air in it.   In addition, after you close the throttle, the plenum goes under vacuum, around 0.25 bar is not unusual, that's another 1.6 litres.
So when you close and reopen the throttle 7.8 litres of air flow dulls the response.  On a 3.1 litre engine that's almost 5 revolutions of the crankshaft, at 7,500 rpm that's 666 milliseconds.  That's more than 10 times slower than the gearbox will handle.  To translate that into distance, at Bathurst it would mean we would be lapped twice during the race distance
Another way to look at it, Nissan designed the GTR to win races on the circuit, if they thought a single TB was better then they would have used it.  Let's face it, a single TB is simpler to make, therefore cheaper, easier to tune and maintain.  But Nissan went for multiple TB's, why?  Because for their stated aim it was superior.
Let me close off with;
An 85 mm butterfly or a 100 mm butterfly, it makes no difference in the example I have given above. It is the volume of air between the butterfly and the inlet valve that matters. Obviously if the turbo can supply more air than will flow though the buttefly, then bigger is better. But I personally have used a standard RB25 TB and inlet up to 450 bhp and it is certainly not a restriction at that power level. I have seen a Zeni Tani built 550 bhp RB25 with the standard TB and inlet and it did not seem to suffer either.
Regardless of whether it is for road or circuit, as most people know, I hate cars with poor throttle response, turbo cars already have too much for me, even at their best. So I see no reason to make it worse and, if everything else is equal, a single TB WILL make it worse. Well up to a power level that I have yet to exceed anyway.
If you are intending to use a MAP sensor driven ECU (not an AFM driven ECU) then go with the single TB, it makes the tuning so much easier. Multiple TB's and MAP sensors are not happy together.
Hope that answered your question. :)
sorry to be off topic but every post i see from sydneykid is of excellent quality and as others said he is teaching everyone something new :D
keep it up
so also with my rb26 with 6 throttles bodies, and autronics be a problem to tune with more power? (currently got 350hp atw, 12.0 @ 118mph)
cheers
Brad
i will be using a power fc with the single tb. Im alittle worried about the difficulty of adapting the gtr plenum to my rb25 head. Seems port design is different. i have no idea.
Power FC runs AFM's so the multiple throttle bodies would be OK. :D
You didn't really think that Nissan would make it easy to put RB26 (flagship) stuff on an RB25, did you? They simply didn't want the value of GTR's being deminished, so they made it as hard as possible. :headspin:
cheers
Brad
Hi Brad, not a problem for the Autronic, if well tuned of course, they can handle multiple throttle bodies :D
SK? so how hard is it to mount the gtr plenum to a rb25det? (r33 model) what mods would need to be done?
And to add to that, do u know anyone that could mod to fit the rb25 and wat price am i looking at?
SK u have turn me off the greddy plenum and onto the gtr one :D apart from the cost factor, by the sounds it much better :D
SK u have turn me off the greddy plenum and onto the gtr one :D apart from the cost factor, by the sounds it much better ;)
Honestly it is cheaper to buy an RB26 top end and sell the RB25 top end, than it is to fabricate the stuff to make it fit an RB25. Plus you get all of the RB26 advantages, solid followers, valve springs, valves, ports, combustion chamber, squish etc etc. And the other parts, cams pulleys, no VVT etc are much cheaper and easier to get second hand for an RB26 than an RB25.
I have done the numbers 20+ times for people, it always works out cheaper in the long run, you get a better result and it's much easier to sell if you ever want to. :D
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
