Ive found the wiring job done on my rb25 silvia wasnt the best, heres a list of the wires the ecu is missing. perhaps they may relate to fuel consumption problems?
5, 14, 15 (DT1, DT2, DT3 signals from Auto) - not needed as manual car
17 - Injection pulse (Ti monitor) signal
19 - Power steering oil pressure SW signal
21 - RX Receive (consult)
22 - TX Transmit (consult)
25 - Boost control solenoid sig
31 - CLK (consult + anything else?)
33 - Exhaust temp warning lamp
44 - Neutral SW
47 - CHK (consult)
53 - Vehicle speed sensor
56 - Throttle opening output signal
57 - Exhaust temperature sensor signal
104 - Fuel pump terminal power control output signal
now the problem is finding these wires and getting them hooked up. are there any i should leave? any that seem desperately serious? aside from fuel consumption, had i never checked the ecu i wouldnt have realise so many are missing.
https://www.sau.com.au/forums/topic/51525-ecu-missing-12-wires/
44 - Neutral SW
47 - CHK (consult)
QUOTE]
Doesnt wire 53 destroy the speed cut ?
That carnt be good with thoes conncetions missing ...:bonk:
Maby another ecu harness ?
yer the 53 one probably doesnt matter
the harness says something like "r33 5mt series 2" or something. main problem with harness is that its missing the pins to put on the wires to insert into hardness - can u get these elsewhere?
the ecu has this on it. i didnt see any leds on the back near the screw:
P5 (barcode here)
Nissan 23710 21V02
MEC-R522 | A1 | 4516
Hitachi Ltd, Tokyo Japan
Made in Japan
on the side (or the plastic film on back near screw, forget) it had:
MEC-R522 | A1 | 0016
what ecu is this? normal r33 s2 manual ecu?
The most common cause of high fuel consumption is located at the end of your right leg.
You don't need any of the "consult" wires (21 22 31 47) - they are for the Nissan diagnostic tool.
You don't need 53 - 180kph limiter
Probably don't need 104, unless your car has the hardware associated with this wire.
You can probably get away without 19
56 is an output - I know it's for the ATTESSA system in 4WD models. Also for Auto Trans. You probably don't need it.
Not sure about the "engine temp warning" wires - but I'm running an aftermarket ECU without this function, and it seems to go OK.
some of those may be related to cold start cycle though, which may harm fuel economy.
one of the main causes of bad fuel economy is generally a ****ed O2 sensor, but it wouldn't suprise me if 56, 57, and 104 also are used by the ECU to regulate things.
bad fuel economy, you should check the 02 sensor and its wire to the ecu.
the oxygen sensor is the same part thats used in the ford ea falcon, around $120 part and should be replaced after 40,000kms according to nissan service manual, when its dead it doesnt give correct feedback to the ecu regarding fuel and lean mixtures. the single purpose of the 02 sensor is to tell the ecu to save fuel and nothing more
the boost sensor wire is only required if you are using the factory rb25 boost solenoid. if you are using the rb25 stock boost solenoid youll be stuck in 5psi until you connect this wire to the ecu (will goto 7psi over 4500rpm) or you can constant ground the wire on the solenoid and it will be in 7psi mode all the time
btw ive replaced the o2 sensor with that el ford one, and it did bugger all for fuel economy (from ~17l/100kms to 15-16L/100kms). i want to get consult happening so that can help diagnose further, but it wouldnt have anything to do with fuel economy. i hardly push the car at all, so can rule out the right foot from the equation. will have a longish drive on the weekend down to wollongong so that may help checking out consumption on longer drives.
im running 10psi with bleed valve, not sure what that means in regards to boost sensor. im assuming im using the factor boost solenoid...
does my ecu seem like the normal one?
hey buddie ive done that conversion before and just now im doin a rb20 conversion wich is heaps silimilar those things that are missing shouldnt be the problem. and 10psi boost wouldnt be the stock boost solanoid. who done the tuning on your car that could be the problem with the fuel consumption.
u cant really "tune" the car at all, just ensure everything is operating correctly. ill be taking to a dyno, probably after i get consult working and can check any other things.
on a seperate issue, i seem to have gone from 1 noisy exhaust lifter to add another 2 noisy intake lifters D:
i talked to mark at hills motorsport and he said something along the lines of the speed sensor for the r32 gearbox i have, is interfacing fine with the s13 dash, just it wont interface with the ecu due to being sine vs square waves, and id need some converter that might cost a lot.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
