I think Im gonna try an 8psi run next time to see my difference in 60ft time.....I launch great with not much wheelspin so some of u guys with minimal mods and boost should be getting 2.1s
Maybe i need to work out the 2 stage boost systym to give it 15psi as soon as i hit 2nd gear as with 8psi i dont even get a chirp
GTSVSPEC......3800 launch?? are you crazy?
Your turbo full spools at 2800 or something like that,
Ive soon your wheelspin in first maybe u should lower the dump rpm
  • Replies 113
Yeah I've tried lower rpm, but when the twin plate bites it really bogs down. I've got to learn to slip the clutch, but it is a much finer line for getting it right with a twin. That's why I need the practice, I haven't found the sweet spot yet.
See'ya:burnout:
See'ya:burnout:
But surely if u let go at 3200 it wont bog down?
Or will it?
See'ya:burnout:
I've got a twin plate in mine, and someone told me that slipping it is VERY bad .... frys it very quickly :)
edit: my grammar :)
Macka, I've been trying with different revs, anything below 3500 causes bog down from a clutch drop, anything over 3800 causes wheelspin launch.
I think 3800 is OK, but I tend to lay the power on too soon, I get excited, and so I start with some traction but them loose it in the blood rush.
Next drags bring some long pants and I'll let you have a drive, see if you can work out where to launch it from.
I don't really want to slip the clutch, with more power even twin plates can fry.
See'ya:burnout:
See'ya:burnout:
You crazy overexcited guy!!
Thanks..Hmmm sounds tempting but id hate for something to let go while i was driving!
And i prolly wouldnt get a better time altho its good to see how other lines are driving :)
I reckon i could of pulled a whole second off ADAM32s best of 14.5 tho.
I tried on that last meet i was there and only managed a 14.5 with first go and dropping it at 4500 i could of done alot better :)
Macka,
I'm not letting you into my pants, you dirty fat bastard. I'm not worried about you breaking anything, if it happens then I'll make it stronger, kind of like evolution.
I'm just worried that you'll crap you pants in excitement, "Wow a clutch that actual bites".
See'ya:burnout:
I think the key is to change one thing what your doing at a time, if it doesnt work revert back and go down another track -- Strich9 i think we nned to organise a R.I.C.E. dyno day if i get a chanbe ill go have a chat to the TREVS at Kiwana Profomance as they just got a new one in there then we should be able to more understand gear change revs etc.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
