Hey,
Well i think it time to add an ecu to my list of mods, and after doing abit of research wolf3d looks like the best opinion for the price it is :) But i still got a few question so if anyone could answer them it would be very helpful
1.I was told that the PLUG in PLAY Wolf3d does not do anti-lag and rotational idle is this ture?
2.possible to have antilag and rotational idle on a switch (on/off)?
3. I know with wolf u can hook it up to ur lap-top, whe u buy the wolf does it come with the ecu to pc cable and all the software? and can u view data in real-time while driving
4. What is the average price for the newest wolf3d (i havnt been able to find this yet) and install and tuning it with antilag, roational idle (if it can have it) on a stocky r33?
5. At the moment im running a Greedy ebc, is it worth removing it and just using the wolf to do the boost or should i keep it?
Thanks Mike
p.s yes paul i know antilag will kill my turbo :D
https://www.sau.com.au/forums/topic/51622-wolf-time/
i can answer first question - i know it can run rotational idle :) Pauls car runs it occasionally - when steve wants to annoy him :)
nobody really runs Antilag on the street ...... only on the track ..... have you thought about how much it would cost to run antilag fulltime? :D
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021095
Mikey - im gathering you've never seen ca rthats running Antilag - cos if you had you'd know that its hardly wank factor ...... nos is wank factor ..... antilag just makes ya car sound like popcorn.
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021109
wank factory??? - how much to they sell a wank for?
rotational idle and antilag are two terms that your car should not come into contact with... i like the words advanced driver course first... also does the list of mods have a dump pipe on there or have you done that already?
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021116
Sssssh i want to see the fireworks :Bang:
:D
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021120
RiaZ, pretty much everything is getting done at once, dump/front, hiflow cat, ecu, fmic possible plenum, z32 afm, fuel pump, and maybe injectors.
i want to get the ecu in 1st, as i had a dyno run at hyperdrive and the car was pinging at 0.6bar and didnt make that much power
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021125
hey thanks everyone for your great replys, i ask a few simple question and got only a few replys that help thanks niz and b_real
for the rest of you how about if u dont have anything to help me dont post anything at all. advance driver course? yeah good idea seeing as i have crash my r33 how many times? and that i drive like a tottal ****ing hoon 24/7
FFS, DONT REPLY IF U GOT NOTHING TO SAY ABOUT WAT I ASK PLZ!
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021235
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
