  • Replies 80
The ones you just made (pic above this post) are the best lids i've seen.
Looking very aggressive >:) Good job!
Can you post some more photos of that one? With more light if possible and looking staright on instead of looking down.
If you were to sell these, how much?
Cheers~!
Cheers~!
thanx for the compliment, as soon as i get up in the morning i'll post a few more pics.
im quite happy with these eyelids, but i will have about 4 different types for people to choose from.
i knew these latest ones would be the most popular so i cut 5 pairs at work today in case i stuffed a pair or whatever.
the pair in the photo where made from 0.6mm colourbond metal (rustproof i think) sprayed with etch primer rustproof paint, 2 coats, then 3 coats of primer putty to get out any discrepencies, lightly sanded then 3 coats of gloss black followed by one smooth coat of clear laquer, looks professional i reckon.
only problem is i temporarily fastened it with double sided tape so i could post the pictures.
in the morning i'll fasten them down with silicon, that way they'll be secure, but if i decide to remove them one day the silicon will be easy enough to remove with a scraper or just by pealing it off without any damage to the headlight.
i will be selling these eyelids, probably prepared with everything i mentioned above excluding the paint and the laquer, that way all you'll have to do is spray them according to the colour of your car, and gluing them down in whatever way you want...
havent come up with a price as yet, i'll get back to you on that.
thanx for all your input guys, really appreciated.
if you have any other ideas on designs for eyelids for the r33 series 1 let me know ([email protected]) or if you want eyelids for any other car let me know, only problem is i'll need at least the outline of the top of the headlight, if you know what i mean. the way i designed these eyelids was trial and error (cut 1, run to the car, check it, alter it, ran back to the computer, redesigned it, cut it, tried again) or if theres anything you need laser cut also let me know, i have a post in the sau classifieds on laser cut jobs, go there for more info...
well, i think im happy with the final product of the last set of eyelids i posted.
i will be putting these in the sau classifieds for $30 a pair, sprayed with 2 coats of etch primer for rust prevention, followed by 3 coats of primer putty, so all you have to do is spray them the colour you want, and glue them on.
thanx again for all your replies and opinions, it helped alot.
i dont know but how will any1 ever know that your parkers arent meant to be in the front bar and the indicators where your parkers are??
i did it because i thought the orange indicators in the front bar look crappy. plus i wanted some decent spotlights, now i do
laser cut the brackets for them too... laser sure comes in handy
  • 3 weeks later...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
