oh well - good stuff .. good to see the cops doing their work.
Well gives heed to the feeling that quite a few of the very top shelf cars around are profits from ill-gotten means. Don't have much respect for those that don't buy their own cars with their own money ;)
I bought my car with the banks money :D :D :D
https://www.sau.com.au/forums/topic/52189-fussy-gtr/page/2/#findComment-1029494
  • Replies 43
S*ck sh*t i despite ppls who looks for easy money, The car was on the news it was a dark purple r33 gtr whit some nice chromies, also a toyota camry and a couple of houses and a few other items or should i say packages that the cops retrieve from roof cavity.
The car won't be for sale until all is out in the open before the courts, that could be a long time from now.
https://www.sau.com.au/forums/topic/52189-fussy-gtr/page/2/#findComment-1029527
yeh i know the car, been told some crazy stories about this guy
All the paint and bodywork was done by dave a cruisin where my car gets done
beleive me, he is/was VERY fussy with his car
well not anymore i guess, poor GTR, will probably goto someone who has no idea what a turbo is let alone godzilla
https://www.sau.com.au/forums/topic/52189-fussy-gtr/page/2/#findComment-1029657
I've seen that car plenty of times around the place and from the onset it is a nice looking car with some decent styling "looks" done to it, just from experience very tidy and slick looking machine rarely goes hard, anyway it'll prolly comes up in the pickles auctions
my bid is 15G
https://www.sau.com.au/forums/topic/52189-fussy-gtr/page/2/#findComment-1030767
hes out on bail, but it doesnt look good for him, hes been done before and didnt exacly get caught with a 'small amount' this time
he lives/lived a few houses up from a mate of mine, i can tell you that damn he was loaded, and from what ive heard has never had a job in his life
a lot of people went down in those series of raids,
i got no respect for anyone who has anything to do with heroin
i guess it just like all the drug movies like blow etc If you get out while your ahead and dont get greedy then youd be sitting on a pacific island with piles of cash before the operation to raid you even began
https://www.sau.com.au/forums/topic/52189-fussy-gtr/page/2/#findComment-1032388
Somehow I don't think his inmates are gonna be all that FUSSY! While he's out on bail, maybe he should buy himself something to bite down on
heh cant do the runner now in his fast car lol.
And as for having no job thru life - looks the tax dept is gonna bend him over....
https://www.sau.com.au/forums/topic/52189-fussy-gtr/page/2/#findComment-1032466
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
