What should I do with my car down the track?
GT Four! either stagea swap or RB30. if you RB30'd it would you use the NA gbox from it or would a stagea one fit?
sell your car NA n then we can stick the turbo on my car! haha jk, rory wants a turbo for his AW11 though...
Depends what you want to do ,Drag it, Drift it, Circut Race.:confused:
The 2 wheel Gt+t is good for the RB26 swap less weight without the 4wd system and damn cheaper than the GTR.
If you've seen in Japan there's a few GTT's running GTR engines even better if you can land the VVT version of the RB26.:jump:
CYA
Hey Dan Go with the RB30 build & be a little different & go with the RB26 top end with a large single turbo on it
I was looking into it & had got an idea of price of around 6K with out turbo & computer just for the motor build & head/manifolds with no turbos.
I have a lot of info on it if ur keen let me know, mind you that build was with head port work & a 30 thou over on the block with pistons & rods with a fully balanced bottem end I got told it should be good for around 350 at the wheels with the right set up injectors & cooler, only prob with the big single & head port work is it will be very lagie but once it on hold on ;) I don't have the money to do what I wanted to do now but looking into KAPA with super charger kits ;)
there was a rb25 complete for $2000 on here in QLD.. still available last i checked.. loom, ecu, afm, everything..
would be a non-neo r33 engine.. but at that price worth considering
otherwise you get Rb30 blocks for a couple of hundie, and rb25 heads for around $1000.. throw in some cams .. the rebuild costs you a few thousand but that is with the serious bits. Near $10k you can have 350-400rwkw engine if you like.. add a nice turbo and start blowing up drivetrains.
rb26 head is a little too expensive.. flows better and tougher but $1000-$2000 more.
Hey Dan
Originaly myself and a mate built it but had a few problems so I took it to Power Break and Enginering (near Harrys Diner)
They pulled out my original build - rebuilt/ balanced the whole botom end - rebuilt mild port of the head - put it all back together - put it in the car and got it working for $2500
the engine is completly balanced - bored 10 though and runs awsome!
Just waiting to put on my fmic and power fc now and Ill be almost all done with the 33
rb30 with a rb26 head and single turbo is hardly "a little different"......
Go the 4.5 or 4.1 nissan V8 and put twin turbs on.... even with a stock engine this combo would haul some serious A55! the 4.1 will obviously be a little more rev happy, but the 4.5 will have more off-boost torque....
V8 skylines r.o.c.k! (but im biased)
Thanks riceline, may have a yarn to the guys down there then....something *cheaper* like the RB30DET may keep me happy for a bit before I move onto another car :)
Also what turbo are you using on that...is it still the stock one?
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
