How makes the better adjustable cam wheels for a '98 SII Gts2.5t?
I only want an exhaust cam at this point [or so I have been advised].
I know they are about $200, and HKS, Tomei, OS Giken etc etc make them, but is there any difference in applicacation?
https://www.sau.com.au/forums/topic/52243-adjustable-cam-wheels/
im goin for HKS but alot of ppl told me the Tomei ones are best...
i also heard that some ppl change only the exhaust side in gts-t's and not the inlet side...would like to have some comments on this too if anyone knows...
cheers...ben.
I have had HKS items, and I would say from my experience steer clear. They wore down in no time. I think they're made from aluminium or something, thats why they wear faster. I believe Tomei items are stainless steel and so last heaps longer.
If someone would like to correct me here these please do. I'd rather know the truth than talk outta my arse, but my HKS experience wasn't a good one (WASTE of MONEY) and what I know I got from my engine builder.
Hi guys, HKS pulleys are made from hardened alloy and seem to be the lightest, I haven't weighed all brands though. I have seen 1 pair of worn HKS pulleys and the cambelt was so tight you could play it like a violin. I have seen many pairs not showing any wear, but the cambelts were tensioned correctly. I have never seen a stainless steel camshaft pulley. They would weigh so much it would be like having 3 flywheels anyway.
I use the Jun adj pulleys, they utilise the standard Nissan outer with a billet alloy inner to give the adjustment. So the durability is the same as the standard pulleys with regard to teeth. They are very boring to look at, but I always run covers so you can't see them anyway.
If someone wants to send me one of every type of pulley, we have a rockwell tester so I can confirm the teeth hardness of each brand. It's not a destruction test, you will get them back able to be used. If someone who had a problem with the HKS pulleys had done a proper hardness test and found them to be deficient I am sure they would have gotten more than their money back.
Hope that makes sense :uh-huh:
Try the ones from Speed Technology / EFI Hardware in Melbourne. They don't come in pretty anodised colours, and they don't have degree markings on the wheel, but they are a lot cheaper than the "brand names", and they do exactly the same job.
cheers...ben.
Its to do with the VVT [variable valve timing], if you install a cam wheel on the inlet side, you loose the VVT. The loss then outweighs the benefit. Thanks to SK for this advice.
My debt to SK increases by the hour...........................[i'll end up having to sell my body to science just to get enough money to pay him].
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
