The ƒX[ƒvƒ‰ which ends production in July of this year. This time information of that succession model was caught. As for the succession model of the ƒX[ƒvƒ‰ appearing, August of next year which is 1 year later from end of the current model. The car name does not understand yet.
Simply, descent it does not do the name of the ƒX[ƒvƒ‰, it is secure.
Most those where we would like to observe are the engine by this ƒX[ƒvƒ‰ succession car. As for Toyota in the future, the engine above 2500cc class, they are not the serial 6 cylinders, to all V type 6 cylinders it converts. Also the engine which is loaded onto the new model surf Prado system which fall & this year plans appearance it is new V type, later, it is the direction which consecutively keeps adopting in the new model.
Toyota the aerodynamic volume displacement variation of this new V type engine, thinks of the full line-up, 2500cc, the 3000cc, the 3500cc and the 4000cc, in the ƒX[ƒvƒ‰ the schedule where the among these the 3500cc is loaded. By the way the new model ƒAƒ‹ƒeƒbƒcƒ@ calls the 2500cc and the new model aristo the 3500cc & 4000cc is loaded onto & the 4000cc and new model surf Prado. Looking at these, as understood, after this year, Toyota means to start to the shield putting V6 for the FR.
Feature of these V type engines must be compact. Bring is in the pure sport system which dislikes front heavy.
Well, as for the ƒX[ƒvƒ‰ succession car how doing the 3500cc V6 engine, as a sport unit the ƒ`ƒ…[ƒ“ doing? That is the adoption of the VVTL-i which mixes variable lift mechanism to variable valve timing. This new model sport model, the ƒX[ƒvƒ‰ way is not pure sport, it is made with the ƒeƒCƒXƒg, luxury GT coupe. Depending, being able to meet, it does not use the turbo, aims for world standard with the large aerodynamic volume displacement NA. Even then peak power can expect 300 horsepower over sufficiently. Becoming the problem effect of the self-restriction framework 280 horsepower which depends on domestic specification.
On one hand, becoming same as the ƒX[ƒvƒ‰ succession car matter of concern, existence of the new model GT-R which becomes the ƒKƒ`ƒ“ƒRƒ‰ƒCƒoƒ‹. Either the GT-R of debut schedule without being defeated in January of 2004, the new model 3500cc V6 engine is loaded. However, as for this way twin turbo specification.
This way after all pure super sport, with the unit which considers also race/lace in the Bali Bali can expect 350 horsepower over with room. We would like to expect to also the evolution type ƒAƒe[ƒT 4WD which includes new mechanism.
Because other than this ƒX[ƒvƒ‰ succession model, the super car class new model, 4500GT which becomes the image leader car there is Toyota, you cannot separate the eye. In any case keyword is the " new V type engine ".
https://www.sau.com.au/forums/topic/5244-2004-gtr/
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
